what would cause a sensored motor to studder
i got like 3 runs out of my reedy neo sensored brushless motor and now it studders in when it starts out now...granted it got hot but the gearing is low and im using a lrp esc and nihms (7.4v) it was blazing fast and could pull the front end off the ground from half speed! im using a m8 with the throttle ramp up speed set slower so i can gun it and it wont spin off the line.
once it starts going(not on the ground though) it will take off....its like the sensore is shot, but in the motor or esc? the wire is fine (checked with meter)
What ECS. if you are using the SPX, they have an issue of power being applied while the wheels are off the ground. It starts shuddering, and will only start moving the wheels after you start turning them.
Only thing you can do, get your receipt and send the ESC in. Its done.
motor can be shorted on one coil. due to thermal overload.
