Originally Posted by St. George
Speaking of LIPOs, how many charges are they generally good for? They're just so expensive, I'm wondering what kind of longevity to expect from them.
Considering the longer run time, mostly do to a higher mah availibility, and the fact that you can charge them numerous times a day, versus the recomended 3 to 4 times for a NIMH pack they are actually cheaper.
Figure you have to buy two stick packs, charging one while the other is cooling, and so you dont over use them - which causes them to loose battery life. You can buy one lipo battery pack and have the same results.
Price out a good matched NIMH pack and your looking at $60 - $80 when you include deans plugs and battery bars - and or buying an assembled stick pack for $45, your still going to need two NIMH packs to get the same overall results with one lipo battery. SMC has a good 6000 mah pack 28c discharg rating for $89.
With a 19t or 10.5 in a buggy you can get almost an hour run time with one full charge. (6000mah)
Lipo is definately cheaper in the long run.
Also in my b44 I replaced three matched cell packs, which cost me $70 each, with one Lipo saddle pack that cost me $120. If I would have done that from the start I would have easily saved $90. and the cost of a smart tray battery balancer.
