XXT
The easiest way to tell is if the rear t-plate under the transmission and the pivot support is one piece.. the CR versions had separate t-plate & inner hinge pin supports. The rear arms were also different too.. the lower shock mounts screwed on to the arms on the CR and were molded into the arm on the original. The carriers were different too.. the CR had rounded carriers with 2 positions on them.. Basically the CR and original XXT hand different rear end parts... that's about it.. if you still can't tell... take some pictures of the rear end stuff and post them...
Jerome
Jerome
Jerome
Jerome
