I have some off neutral issues with my MMM and Medusa 60x2000 combo in my 8ight buggy. If you are under some power coming into a jump it is pretty good, but if you have a tight corner into a jump it can be unpredictable. Sometimes you get too little power and next time you pull just a bit more and way over jump. I believe I'm running 20% punch control, maybe I need to run more or setup a custom throttle curve.
This is a Medusa issue (I have one). The CCNeu motors are smoother than Medusa & the Tekins are smoother yet. Do you have the latest firmware for the MMM? if not that will help you. What is your timing set at? Medusa's need a little more timing (10 to 20).
Mine's smooth as can be. I have a little expo dialed in, just to make the throttle more progressive. But I've never felt slow or unpredictable with it. I wonder if those were voltage/amp spikes. With the amp draw that ESC can make, I've seen batteries pretty heavily stressed. Mine are all relatively new, and perform very well. I always feel confident with the throttle. The track is tight and technical, so I use the throttle and brake ALLOT.
using a TC spec would be a waste especially with most other esc's being later technology.
Anyone else? Anybody actually tried it? If it good enough for Maifield and Cavaleri it can't be a total waste.... I'm just curious cause I have one laying around and would like to hold off buying anything else til the LRP SPX8 is released
Trinity, Ko Propo, Fastlane GraphiX, Leisure Hours Raceway and Hobbies
