Lipo 4S or 5S
from what I can gather a 1700-2000KV motor running on 5Cells is the most efficient set up you can run.
Alex
Alex
5 cells will give you ALOT of power... Alot of people run 4 cells just so that it is more controllable, but if you really want you can get the 5 cell just for longer run time and turn down the throttle to have the same controllability of a 4 cell; that's what I would do if you have the money .
-J
I have driven a Mamba 2650kv system on 4s and a losi 2100 system on 5s in a losi 8 buggy and the 5s will feel a lot more punchy even with the lower kv. It will be more efficient and should create less heat on 5s. If it is too much you can turn it down either with your epa on the radio which would give you more run time because you would not every be using full power. Or your can change the throttle curve on some systems so it ramps the power up slower. Also the 5s packs from losi are cheaper than their 4s packs.
Jason
