*****YOKOMO BMAX 4*****
#2341
nah, 10.5 25/84 gearing. the 22-4 jumped the pipe and it was a high speed head on crash. unavoidable. that crash broke the tower, arm and a hinge pin. the last arms broke going over an off camber double where I clipped the pipe. they way it broke, makes me thing the plastics are soft. the pin was pulled through the plastic, but no plastic broke off. the car drives great. i just need to dodge 22-4s better. also, the ball studs seem like crap. I replace the ones in the rear hubs with AE studs and cups. I was definitely faster in the tight corners than the other wheelers. the car turns on a dime.
#2343
Contact Dennis from rccss.nl, maybe he can help you.
#2351
So I order this part and you are saying your what white machined? I just ordered it as a spare in case the motor comes loose and trashes the spur.
http://www.amain.com/rc-cars/yokomo-...m-sg84/p270520
#2352
I use an 81 but you will probably get a white one. Rolling change, same part numbers.
Clint posted a pic of one here from when I was asking about it myself: http://www.rctech.net/forum/13861799-post2140.html
I believe I read about the switch to machined on Oople or something similar but I can't find that right now to totally confirm it. With Yokomo, ymmv always.
#2354
I know exactly what you mean, but this is a good thing. It feels as though no two kits are the same, but wouldnt you have a manufacturer that addresses issues as soon as they're aware of them. Or even offers upgrade parts "just because"? I think its sheer class. Are ther any other manufacturers that do this?
#2355
