can anyone help
can anyone help
im a newbie to lipos and was wondering if anyone could help.
i have the onyx 230 charger and have 3 batteries
1. venom 7.2volt nimh 500mah
2. venom 7.4v 4000mah lipo
3. trinity 7.4v 4500mah lipo
i could really use some help on setting up the charger thanks in advance
on the onyx charger plug it in and push the right button it will go to batt setup, push the center button once it will ask what type of batt, select the type, then push it again, it will ask for the milliamps, then cycle thru it and do what else it asks for, that will be for that batt. next push the center button once and there will be a # in the top right corner push the right button 1 time it will change to another model #, the batt model you have programed in will scroll across the screen with the batt size and charging amps, then push the center button again and start over again by pushing the right button again to get to the batt setup, etc...... .
hope this helps james
