RPM arms, just to confirm
Is is the GT2 front arms that work on the T4 and Sc10 right?
http://www3.towerhobbies.com/cgi-bin...&I=LXRFW4&P=SM
just want to double check
also the GT2 rear arms are direct fir for both?
yes the gt2 arms are what you want.another thing to try is the regular gt2 arms they are alot stronger then the regular t4/sc10 arms.i havent broke one since i swap over to them.i realy dont like the rpm arms they make the truck feal weird.i think they flex to much for my liking.my self i would just go with the gt2 arms and castor blocks.
yeah for bashing you will be ok.but i would still consider the gt2 front arms.i dont know why but these are way stronger then the stock arms.i have beat the tar outa my sc10 and have broke a single part after the swap.first time i jump the truck with the stock arms,i broke a arm.castor block,and a shock shaft.
If you use the GT2 front arms do you need to change anything else or are they a direct replacement? Not the RPM front arms but the GT2 arms from associated. Thanks
How do you bolt the shocks in then. Do you bold them tight to the one spot? And is this strong enough so that the bolt doesn't move around? Thanks
