C-CVDs for the B4
C-CVDs for the B4
I just put a set of C-CVDS (the ones with the red caps that thread on to the bones to capture the pins) on my FT B4 and the red pin capturing component is rubbing the a-arm on one side only when the arm is fully extended. I checked the rear shocks to make sure that they are absolutely the same length and they are. I compared the distance between the top of the rear shock tower to the hinge pin capture screw on the a-arm on both sides and they are the same. The only thing I can think of at this point, is that the red pin capture on the one bone is larger than the other. I will in fact need to confirm that. However; I guess my real question is; will this "rubbing" when the arm is fully extended really be a problem? There is obviously no rubbing when the car is at its normal ride height or less.
I am also curious to see if anyone else has come across this issue.
Thanks.
Thanks.
Make sure the camber links are the same side to side. If one is too short it bring the hub in and angle the cvd down. This will most likely be the problem. CHeck to see if the cvd is shimmed on both sides equally as well. If all else fails just dremel off where it rubs and your good to go.
Thank you,
Kyle
