Losi Plastic Spur gears on Eight E
Running 2200kv with a 12T Robinson and a 45T spur, have the esc at 80% and striped 2 spur gears. Made the 15min of qualifing then destroyed them both in the mains.
The spur is close to the aluminum tower, but other then that? Any ideas on how to correct this?
mesh
I adjust it tight enough so the spur gear just moves. I'm going to start running steel, but just thought I'd check before I start destroying steel.
I've got a whole season out of a plastic spur (a Kyosho on a Losi 8 diff) and am still running the same spur this year. Lots of other people get good results and long life with plastic spurs. Wonder why it never occurs to people that destroy stuff fast that it might be them that is doing something wrong?
My point exactly
I know they work, I've been running them in my other buggies for 6 months no problems. This buggy is chewing them up.
You've stated it maybe the operator, but haven't offered any ideas as to why they might fail??
Other than the obvious, having good mesh, I would say that if you're direct drive, 2200kv (assuming 4s) is a fairly hot setup, and quite a bit of pressure to be putting on that plastic spur. Steel, Sliperential, etc, are the directions I would look in.
Very good insight there.
I'll check into that. I haven't touched it since the race, so hopefully I'll be able to see what happened.
A 4-cell 2200kv and with a 12tooth and a 45 spur is a hot set up? I guess I better go steel, its only going to get hotter from here!
Myself, I'll take the extra noise. Just wish I had the option to run a slipper...
I have still never stripped a plastic spur gear in all the racing and bashing I have done with electric 1/8 buggy and truggy.... unless the motor moves and makes the gear mesh real loose. That has happened a couple times. Otherwise, never stripped one out... even when running a stupid fast bashing setup.
