Whats a cheap brushless system for a traxxas slash
just wanted to know cause im wanting to buy one
I just picked up a Hobbywing ESC/17.5/Programmer combo for my SC10 for just over a $100.00
Not sure if your looking for a bashing set up, or a racing set up, but these combos run from 5.5s to 17.5s. The link is for an 8.5 combo.
http://cgi.ebay.com/eZrun-RC-1-10-12...A12%7C294%3A30
Novak Havok for $140
I second the Sidewinder. Castle Products are top notch for less money. I know these setups can last virtually forever.
I also give good props to the Hobbywing, I have one and a few friends have them. Works great, had them for a year or so with no problems.
the vxl esc has some lvc issues if you were ever to go lipo that would give you some problems. if you want a inexpensive setup for bashing take a look at the ez run systems, itll run around $100 for everything. if your looking for something that you might race with someday id go with the mamba max esc and the vxl motor
Actually. $140 for a BL system is on the cheap end.
For bashing, look in the for sale section, you can probally get a velenon system out of a traxxas rather inexpensive.
Remember you get exactly what you pay for. Meaning too cheap now, will cost you more in the long run when you have to replace it.
Good luck.
Good luck.
i think he is lookn for something a bit less expensive than a mm system, for bashing around the yard
Though you said you wanted BL you can get a new brushed motor and esc that are superior to what you already have, for well under $100.
It may not be what you initally what your looking for, but I just wanted to through it out there. Especially because your just bashing with it.
