piggybacks
piggybacks
Im having problems with rear piggybacks (integy) on my slash bottoming out.
I got them yesterday,downloaded instructions from integy,followed them to the letter, have 2hole pistons 35wt.oil,red springs,preloaded all the way. NO LEAKS
STILL SLAPS GROUND OFF JUMP ONLY 8" HIGH! Any and all help will be GREATLY APPRECIATED!!! THANK YOU!!
Have you tried adding more preload or stiffer springs? If you like your spring setup, you could also add some O-rings to the shock shafts to limit the travel.
hey i have the integy msr9's to and i have the same problem get 80 weight oil and put the red springs on right now i am using the old shocks with red springs and 55 weight oil and they work great the old shock are shorter than the integy so they have more travel but with the more travel then the more oil you need
I USED 60wt. and stock dual rate springs on the piggy's with preload at about
1/2" down seems to be working fine. thanks guys for the ideas.
did anybody add spacers under the blue rubber shockstops? if so what did you use and how thick? shocks seem to travel farther than they need to, so truck bottoms out. Any ideas??????
ya you will need to go thicker weight and put the red springs on and adjust the shock to the high position on shock body and then try it and see if it doesn't bottom out i would go maybe 70-90 weight oil the slash is a pretty heavy car in the rear but keep trying and let me know
