24-28 or 40 C lipo
24-28 or 40 C lipo
24-28 or 40 C lipo 2S What is the difference between each of them. Lets say they are all 4000 2S lipo. What make better a 24c over and 28 or 40C and HOw does it make it batter when you see the car runing in term of power time running heat etc. i kinda confuse on this
https://rc-mushroom.com/advanced_sea...s=lipo&x=0&y=0
I'm looking to other this hardcase lipo from SMC
The amount of C is how fast the battery can discharge when the motor needs the power. Basically the higher the C, the more power can be giving to the motor and is usually the better battery. Some of the Brushless motors need at least 25C+ to operate efficient and have the power when you need it. The amount of C though doesn't do anything for run time and speed. If your motor only needs 25C and you have a battery with 30C and one with 40C. The speed and run times will be the same. Of course the higher C battery won't be working as hard and should have a higher life span.
The SMC batteries are great packs and you should have great luck with them.
Thought I'd update everyone, the 4 Zippy lipos I bought are working great I have 2 Orion 3800 carbons and these work just as well and at $27 just can't be beat:
http://www.hobbycity.com/hobbycity/s...25C_Car_Lipoly
But you Also have to remeber one companys "40c" pack could be the exact same thing as a company with higher quality control "30c" pack. Not all compaines packs go through the same testing to achive a C rating.
