sensored or sensorless
Sensored knows where the rotor is at all times, but on the flip side, usually can't handle as many volts. Sensorless is probably more popular.
The sensored motor eliminate almost all cogging because like was said it knows wheres the motor is at all times. Where as sensorless only approximately knows where the motor is and because of this can cause cogging. Where you mostly see the problem is if you spin out and roll backwards. The motor might clog when you give it throttle again. The sensored motors usually use more power and like what was said usually only handle up to 4S. Tekin new ESC uses both sensored and sensorless to get the best of both worlds. It uses sensored on the start, then switches over to sensorless once its moving. I am using the MMM and I havent had any cogging issues at the moment, and alot of people I know are running it also and are not having any issues as well.
For racing sensored is by far the most popular as it eliminates any chance of cogging.
Sensorless systems are generally cheaper and popular for bashing, they can be used for racing as well in mod class.
The sensored motor eliminate almost all clogging because like was said it knows wheres the motor is at all times. Where as sensorless only approximately knows where the motor is and because of this can cause clogging. Where you mostly see the problem is if you spin out and roll backwards. The motor might clog when you give it throttle again. The sensored motors usually use more power and like what was said usually only handle up to 4S. Tekin new ESC uses both sensored and sensorless to get the best of both worlds. It uses sensored on the start, then switches over to sensorless once its moving. I am using the MMM and I havent had any clogging issues at the moment, and alot of people I know are running it also and are not having any issues as well.
Cogging is when you go to give the car throttle. And the vehicle hesitates to accelerate. I guess you can kinda describe it as a Low Speed lean on a nitro vehicle. It is a bit different though.
Actually it is cogging, not clogging.
LOL my bad
It kind of stutters a bit until it starts picking up more speed.
Sensorless is not so bad. It could be my imagination, but once I updated the firmware on my Sidewinder ESC, everything was a lot smoother.
I like sensorless for the cost factor if nothing else. I get a little cogging with my 3300kV motor on the Sidewinder, but nothing to worry about. I know it will be an issue when I use it against Tebo in the A-Main, but until then i'll just muddle my way through.
I have a Tekin 537 coming with an R1 I got filthy cheap from Tower of all places! Be interested to see how that goes with cogging. They are supposed to be a lot better as they have low turns for the kV. Fingers crossed!
Tech Legend
Trader Rating: 51 (100%+)
If you want to run the 17.5 stock class then a Sensored type setup is better.
Go with sensored if you are racing or are on a slippery surface. Go with sensorless if your just bashing and want crazy speed. (Slash + MM 7700= )
Sensored motors not only elimate cogging, they typically provide better throttle control. If you are racing, you will benefit greatly from a sensored system.
The majority of folks at our local track are brushless.. and run just about everything out there. The only folks that have cogging problems with sensorless setups are those with cheap sport packs and old worn out race packs.
For the same price as a sensorless, you can get budget minded sensored systems like the Novak Havoc with down to an 8.5 motor for under $150.
Given the choice, I'd go sensored!
Jerome
Jerome
