Old 04-12-2009, 06:58 PM   #1
Default SBv2 Issues
Awhile back I did some research and decided on a New Academy SBV2. Well, I have not had too much luck with it. I blew out the rear dif, built another one and now the latest one is making noises. The second one with hardly any driving on it.
Needless to say I am not all that pleased with the car. My own non professional opinion is that the SBV2 was designed for Nicads, or NiMH batterys and brushed motors. I am running a 2s lipo with the Castle 5700 motor.
Am I building wrong, or am I over powering this car?
If I am overpowering, then what 1/10 4wd buggy/truggy is a good solid electric car that can handle lipos and a 5700 motor ??? (and doesn't cost a fortune !)
I am planning to race on a 1/10 scale track.
Thanks !!!!
smeyers2 is offline   Reply With Quote
Old 04-12-2009, 07:54 PM   #2
Brandon A's Avatar
Probably the best advice I can give is to go search through the sbv2 thread. There is a lot of good info, but you may have to dig a little.
Academy's new 1/10 scale buggy SBV2 PRO
There is a detailed walk-through of building a smooth Academy diff on this page from the Gv2 thread.
New ACADEMY 1/10 scale 2WD BUGGY
Also, do you have the metal outdrives or the plastic ones? The plastic ones are notorious for causing problems. I prefer using associated diff grease as opposed to the kit stuff; it seems to last longer and make the diff action smoother. The slipper should slip before the diff, and the diff should not be run loose or the rings will groove really fast.
RCAmerica/Xray <> Panther <> RW Mods
Brandon A is offline   Reply With Quote
Old 04-12-2009, 08:43 PM   #3
Thanks Brandon... A lot of good info there... will rebuild another diff and check the slipper...
'Nite !!!
W.A offroad racing nhodd Australian Racing 3555 11-18-2014 11:01 PM
New ACADEMY 1/10 scale 2WD BUGGY rcforum Electric Off-Road 3794 09-30-2013 07:57 AM
Academy's new 1/10 scale buggy SBV2 PRO rcforum Electric Off-Road 2964 12-10-2011 11:16 AM
SBV2 pro buggy, is it any good? palmtreeRCer Electric Off-Road 49 08-27-2008 12:01 AM
b44 vs sbv2 pro Deaths-a-Bitch Electric Off-Road 64 12-07-2007 02:07 PM
Cheap Brushless parnelli97 Electric Off-Road 35 08-07-2007 03:33 PM
SEO by vBSEO 3.5.0
