Old 04-09-2009, 08:24 AM   #16
xDaRReLLx87's Avatar
Originally Posted by asbe88 View Post
i have a b3 and a b4 but I'm talking about my b4.. it tends to turn too sharply and the rear spins around with the front so i can often end up facing sideways
sorry for the late response
But i dont't think that information really matters now since to be honest i think this thread has come to its conclusion, unless anyone has some facts not been pointed out before.
Well that typically means you don't have enough rear grip You can't adjust much to fix this if your tires are defiently the wrong tread. Tires usually are the first thing to inspect. Adjustments are made after in most cases. These adjustments talked about in the 2 links in previous posts really help you once you have the right tires
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Old 04-05-2015, 06:50 PM   #17
Hey i have a rustler xl-5 and i have a problem....just went to practice at a track for the first time (I'm not a newbie but was just my first track experience) and my truck didn't turn very well.... i already going to get lighter weight oil and use traction compound on front tires but want to know how to fix this problem....i have a way of putting 3 rear toe in but no way to change front....should i use front/rear toe in/out or are there other methods to fixing this problem?
Conor is offline   Reply With Quote
Team Associated TC4 Kenshin Electric On-Road 14930 10-18-2016 05:57 AM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
Jammin X2-CR ?? (buggy?) orzel24 Nitro Off-Road 441 05-13-2015 06:34 AM
LOSI 1/8 NITRO BUGGY TALK... STARSCREAM Electric Off-Road 192 04-12-2006 04:18 PM
SEO by vBSEO 3.5.0
