Making the transition to dirt tracks, need tips please >
Old 04-07-2009, 04:51 PM
tennvol11's Avatar
Trader Rating: 8 (90%+)
Default Making the transition to dirt tracks, need tips please
How big of an adjustment is it to go from a carpet track to a dirt track. I was wondering what type of adjustments have to be made suspension wise going from a carpet track to a indoor/outdoor dirt track. I am going to race on dirt tracks this summer and I only have indoor carpet knowledge up to this point. I am just looking for some tuning pointers regarding suspension, shocks, and gearing to prepare for the dirt. Thanks
tennvol11 is offline
Old 04-07-2009, 04:54 PM
Shocks you might want to run thinner oil in, to absorb the bumps more, maybe slightly lower gearing (depends on track), and a slightly higher suspension. All mostly to soak up the bumps so it isn't thrown around like a rag-doll.
howtowakeakar is offline
Old 04-07-2009, 04:59 PM
tennvol11's Avatar
Nice, so instead of running a little lower on the carpet, I should run a little higher for the bigger jumps. Wouldn't you want heavier weight oil to absorb the jump better??
Old 04-07-2009, 05:05 PM
xDaRReLLx87's Avatar
more vertical shock angles for absorbing jumps, most carpet tracks do not have big jumps, so I wouldn't put them to vertical or you will push. A stiffer oil will make it turn better along with a stiffer spring rate. You have tremendous grip on carpet, however you will have more of a slide feel on dirt. The only transition you will have difficult with at first is when you get in a slide and have to correct yourself, other than that it is very similar.
xDaRReLLx87 is offline
Old 04-07-2009, 05:21 PM
tennvol11's Avatar
These tips were very helpful thanks a lot
