Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-06-2009, 10:03 AM   #1
Kevin Boyle's Avatar
Default Team Associated 1/8 Electric Buggy Info and Tips
Hello Guys,
Looks like there are several small threads started about the RC8E conversion kit and other RC8 questions, but no main thread. I thought this could be the thread to talk about it all.
I have the conversion kit on order and I plan on making some upgrades when the new RC8 parts are released.
Let talk about the ESC systems that are being used as well as tires etc.
I can only see the eletric 1/8 getting bigger.
Post any set ups or tips you have.
Thanks for your comments
Kevin Boyle
JConcepts-Team Associated
Winning Edge Designs/wedjim.com
RC8 - RC8T - BJ4W.E.- B4/T4-TC5
Kevin Boyle is offline   Reply With Quote
Old 04-06-2009, 02:08 PM   #2
AndyMoore's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to AndyMoore
Tip #1: Dont let the smoke out of your MMM.
|Kyosho America|Team Orion|JConcepts|Jab Graphix|oOple|Winning Edge Designs|RC Signup|Pacific Coast Hobbies|
AndyMoore is offline   Reply With Quote
Old 04-06-2009, 03:33 PM   #3
CRCDUDE's Avatar
Default rc8
Hmm, where to start.
Ups =
Aluminum front chassis brace
Kings or EQ A B C D plates GHEA has some real nice stuff
Steering mod
RC8T shock tower mod ( really squares up out of turns)
Plastic Kyosho spur
Setup:
MMM CC 2200 + Zippy 4S 20C 5000 geared 44/18 = 18-22 min run times
Be sure to ZIP TY the MMM or IT WILL FAIL!!!
Worlds setup does not work for me at all, I need way more steering so here goes.
Front= Blk spring/1.3x6/30wt/Blk sway bar/14*/2up topfr/2upbotfr/camber hole inner/2mm bump w steering mod. Shocks up/out
Rear= Bronze spring/1.3x6/25wt/silver sway bar/2* toe/3*squat/ camber hole lowest/ shocks up/out w RC8T tower /29mm shafts
Diffs are 3000/10000/2000
Any tips on getting more turn in (off power) would be appreciated.
GOT TRIPLE!!!! GEAR IT LIKE YA HATE IT !!
Special Thanks to:
Avers Electric
bcespeed.com
Team Terribles
CRCDUDE is offline   Reply With Quote
Old 04-06-2009, 03:50 PM   #4
rearviewmirror's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
grrrrrrrrrrrrrrrrrrr x 2!
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 04-06-2009, 05:23 PM   #5
Let keep it rolling with the input, even Andrews info LOL.
I know AE is coming out with plastic spur gears as well.
I will be back soon to talk about the car
Later
Kevin Boyle
Old 04-06-2009, 06:03 PM   #6
Kings Kid's Avatar
Trader Rating: 22 (100%+)
2mm toe out,& lose the front sway bar.
Kings Kid is offline   Reply With Quote
Old 04-06-2009, 07:23 PM   #7
Tim3's Avatar
COME ON MEN, POST SOME PICTURES.
1/8 scale is changing be fore our vary eyes. this new part of the hobby is about to explode with all out electric buggies truggies and any thing bigger than 1/10 scale. You/We are changing it fore ever. its coming
Tim3 is offline   Reply With Quote
Old 04-06-2009, 07:36 PM   #8
Jube's Avatar
Trader Rating: 34 (100%+)
Here is my FT RC8 Tekno w/ MMM 2200 combo
team-associated-1-8-electric-buggy-info-tips-spring09car-086.jpg   team-associated-1-8-electric-buggy-info-tips-spring09car-087.jpg
Jubal Dike
Avers Electric Co~BCE Speed www.bcespeed.com ~Team Tekin www.teamtekin.com Fastlane Graphix www.fastlane-graphix.com ~JCP RC www.jcp-rc.com ~AVID www.avid.com~Team Terribles
Jube is offline   Reply With Quote
Old 04-06-2009, 09:34 PM   #9
Nitro182's Avatar
Send a message via AIM to Nitro182
Havnt had any problems with both of my MMM's thus far. The V3's are the way to go. Only reason I have heard of them going now is b/c people are putting too much voltage through the internal BEC.
BeatYourTruck.com
WolcottHobby.com
sgm182.googlepages.com
Nitro182 is offline   Reply With Quote
Old 04-06-2009, 10:08 PM   #10
Sylvéris
Guest
Posts: n/a
Hi, here you can find the first pictures of my RC8, with all accessories and modifs :
http://sylveris.free.fr/serie2.html
Be carefull with the motor choice, due to the 3mm and 4 mm motor mount screws !!!
Will post some comments and videos on my website later, but it's under construction...
Old 04-07-2009, 08:17 AM   #11
Cain's Avatar
I run an RC8FT with RC Product Designs conversion. What I have found is that if you use the Neu 1512 2.5D/F motor, you don't really need to stray much if it all from the nitro diff setups. I currently run 5-5-3 and it works quite well. I also use the plastic chassis braces with no issues, and the aluminum top plate now.
Academy GV2 Pro 1/10 Scale Brushless Buggy
Academy STR4 Pro II 1/10 Scale Brushless Sedan
Ofna Hyper 9E 1/8 Scale Brushless Buggy
Old 04-07-2009, 09:22 AM   #12
AndyMoore's Avatar
Illuzion - RC8e - Hi-Flow body
Old 04-07-2009, 09:24 AM   #13
Hey Guys,
Since I am new to the Electric 1/8th scale I do have a few questions.
1) How is the weight distribution?
2) What are the average run times of the cars?
3) How does the car handle with breaking (not parts)
That is it for now
Kevin Boyle
Old 04-07-2009, 10:28 AM   #14
Cain's Avatar
Originally Posted by Kevin Boyle View Post
Hey Guys,
That is it for now
Kevin Boyle
Weight distribution depends on the conversion and battery pack size you use. In my case, I use porky 6000mah 4S battery packs, but, even though they do bias the car weight wise to one side, it handles excellent. Using a standard 5000mah pack I would say the car would be very well balanced. If balance is important to you, you may want to look into conversions that move the location of the center diff over to allow better balancing of the battery pack weight. I have the RCM conversion for my RC8T and it does an excellent job of this even with my porky packs. Tekno's conversions do a great job of this too.
As for runtimes, this is VERY track dependent. I went with a 6000mah pack as I wanted consistent 15 minute runtimes regardless of track conditions. I have dumped this pack in about 18 minutes on a large flowing track against nitros. Running on a more technical or shorter track should really increase your runtimes. I would say that a 5000mah 4S pack will consistently give you a minimum of 12 minutes of runtime even on a high drain track. You may get much better runtime than this though in your experience. If you have a radio that can do it, having telemetry to warn you of when your pack is getting close to dumping (assuming you are doing swaps with nitros or just would like to know) is a good tool.
As for braking, depends on what camp you fall into. If you need braking bias, only option right now is a tekno conversion. Very good stuff in the tekno conversion, I just wish the battery tray was a bit longer. As my conversion uses the ESC for brakes, I don't really use the brakes that much, if at all. I usually coast around turns and then power through. Against similar competition with nitros using mechanical brakes or a similar skilled electric driver using his tekno rc8, I didn't feel I was at a disadvantaged based on where they were using their mechanical brakes. If the pro's start seeing an advantage to this turning into wins, I would say it will be something the next generation of electrics will incorporate (looks like Hot bodies D8E has it in it already). Me personally I would like to see what could be done to simulate the braking bias effect without using a servo to do it. Maybe a center driveshaft oneway clicker like losi's XX4 setup? You could then dial in as much braking force to the front brakes till the car was 50 - 50 braking. Seems most bias is with the rear brakes having more braking force than the fronts (40F - 60R).
I do know I would like to see Tekno's RC8 conversion (mechanical brakes, long shank pinion) combined with the RC Monster center diff slipper and using the Tekin RX8 ESC with its coast feature. I think it would be a killer setup.
Old 04-07-2009, 10:31 AM   #15
kufman's Avatar
Sweet! Looks much nicer than the AE electric body.
kufman is offline   Reply With Quote
Forum Jump
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 7056 Yesterday 10:58 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
