Team Associated 1/8 Electric Buggy Info and Tips
#16
Hmm, where to start.
Ups =
Aluminum front chassis brace
Kings or EQ A B C D plates GHEA has some real nice stuff
Steering mod
RC8T shock tower mod ( really squares up out of turns)
Plastic Kyosho spur
Setup:
MMM CC 2200 + Zippy 4S 20C 5000 geared 44/18 = 18-22 min run times
Be sure to ZIP TY the MMM or IT WILL FAIL!!!
Worlds setup does not work for me at all, I need way more steering so here goes.
Front= Blk spring/1.3x6/30wt/Blk sway bar/14*/2up topfr/2upbotfr/camber hole inner/2mm bump w steering mod. Shocks up/out
Rear= Bronze spring/1.3x6/25wt/silver sway bar/2* toe/3*squat/ camber hole lowest/ shocks up/out w RC8T tower /29mm shafts
Diffs are 3000/10000/2000
Any tips on getting more turn in (off power) would be appreciated.
Ups =
Steering mod
Plastic Kyosho spur
Setup:
#17
1. Weight distribution is good. We ran the Mamba systems as our new LRP systems failed to show up. The Mamba stuff is heavy but side to side it was not far off. We could have added some ballast to balance the car but did not feel it was necessary.
2. The Silver State track was blown out rough with 35-38 second laps. When you count the 1-2 warm up laps, the last lap, and the 10 minute race, we were running anywhere from 10:40 - 12:00 minutes. With my setup I have run about 15 minutes with 5000 35C 14.8V. At this race we made the time no problem but some of the Losi guys dumped or slowed on the last lap. I know people speak abou super long run times, But I think 15 minutes is the very top for a fast driver with a good car.
3. The car works great., to me it drives like a 1/10 car as far as braking and general are concerned.
#19
Thanks for the report, Rick. The Team setup for the RC8e would be appreciated. Of Course, until the new f/r shock towers are available to us, the setups are probably not of much use to us right now.
#21
My ride.
#22
Thanks Rick,
I am glad you found the thread and provided some good info to our questions.
Later
Kevin Boyle
Later
Kevin Boyle
#24
I would wait on that mod if I were you. The team guys have moved away from that and are running the new towers which are different than the truggy tower plus they say there is nothing else to do other than change out the tower. shocks and stand offs stay stock. Thats what I read.
#28
Nice but I would not cut out the holes. Better to keep the dirt out of the fan as much as possible. However in most cases we really do not need the fan so some holes would improve the airflow flow, but I still do not think it would help enough to justify them. Tight and clean inside...
Tekin Prez
#29
Why do you all prefer a plastic spur instead of a metal one?
#30
