Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 04-01-2009, 07:33 PM   #31
Suspended
Nice step-by-step tutorial and build run-through JD.
I got mine today finally, but it was a a weird situation.
My wife had to sign for the package early this afternoon, but there was visible crushing to the box and she thought part of the shipment was lost so the UPS driver had her fill out a form.
But after inspecting it when I got home from the office there was nothing missing (one complete SC10 kit) but the shipping box was strangely oversize for the single kit. About a half-hour after I got home the doorbell rang and it was the UPS driver holding a crushed SC10 box under one arm, with his clipboard in the other ~ "Here's what was missing out of the box, it must have fell out when they were loading my truck and got mixed in with the other packages. Hope I don't get blamed for this."
I told him that I'd handle it, and took the package from the startled driver who shrugged and headed back down the driveway whistling as he went.
On first inspection of the second kit the only thing wrong was the body was pretty mangled.
I'm going to spend the evening stripping off the FT parts from my T4 and cleaning them for use on the SC10, and then start on my own build tomorrow after work.
Build looks like pretty straight-forward T4 for the most part, so maybe I'll work on the paint first so it has an extra day to cure.
Lightin' is offline   Reply With Quote
Old 04-01-2009, 07:37 PM   #32
2wdMod's Avatar
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 20 (100%+)
You got a PM dude!!!
PSI Racing MM2 buggy
academy gv2-t
ACADEMY GV2 SC TRUCK (Yes you read that right)
PSI Racing - bringing the hobby back to the hobby.
2wdMod is offline   Reply With Quote
Old 04-01-2009, 07:44 PM   #33
Crawler's Avatar
So you received 2 kits?
RCShortCourse.com
Panther Team Driver / Kamikaze Kustoms Driver / Team JP Custom RC Driver / Team Brood Driver / Team * Driver / Team RC4WD Driver
Crawler is offline   Reply With Quote
Old 04-01-2009, 07:45 PM   #34
Trader Rating: 21 (100%+)
Send a message via AIM to JDCrow Send a message via Skype™ to JDCrow
Default SC10 Vs Slash Chassis Pics
Several asked for an image of the Traxxas Vs SC10 Chassis. Here you go..
sc10-build-thread-sc10-chassis-vs-slash-chassis.jpg   sc10-build-thread-sc10-chassis-vs-slash-chassis-top.jpg
JD Crow's Miniature MotorSports
Arkansas Championship Off-Road Racing LLC
http://www.arcorr.net
JDCrow is offline   Reply With Quote
Old 04-01-2009, 07:49 PM   #35
Default SC10 Vs Slash Vs JConcepts Truth Bodies
Here are some body comparisons. I blocked up the bodies to be close to each other with respect to the Trim Lines.
SC10 Vs JConcepts Truth
SC10 Vs Traxxas Slash
sc10-build-thread-sc10-vs-jconcepts-truth.jpg   sc10-build-thread-sc10-vs-jconcepts-truth-front.jpg   sc10-build-thread-sc10-vs-traxxas-slash-body.jpg   sc10-build-thread-sc10-vs-traxxas-slash-body-front.jpg
Old 04-01-2009, 07:53 PM   #36
Cameron Kellogg's Avatar
Originally Posted by JDCrow View Post
More pics since the limit is 5 per post
Your rear arms are on upside down and on the wrong side.
Team Kyosho-Team Orion-AKA tires-Dirty Word R/C
PRCR 503-723-6969 M-F 4pm-9pm, Sat 10am-racing over,Sun 10am-5pm
Tuesday Racing Starts at 7:00pm
Saturday Racing Starts at 5:00pm
Cameron Kellogg is offline   Reply With Quote
Old 04-01-2009, 08:16 PM   #37
ckaspar's Avatar
KO Servo
Tekin RSPro Speedo
Tekin Redline 17.5
Futaba FASST Radio System
Orion LiPo
So basically a stock setup. Right on! Thanks.
ckaspar is offline   Reply With Quote
Old 04-01-2009, 08:19 PM   #38
ckaspar's Avatar
Whoops! Forgot to ask what FT parts will work with the SC10. If you know/could tell.
So Far I got:
Servo Saver Nut
Titanium Turnbuckles
Bearings for the steering rack(The same as the FT kit I imagine)
Anything else?
Shocks?
Old 04-01-2009, 08:22 PM   #39
You are correct. I realized that after I ate dinner, and forgot to take a new pic.
Old 04-01-2009, 08:29 PM   #40
Suspended
So Far I got:
Servo Saver Nut
Anything else?
Shocks?
Lots of goodies
T4 FT list = http://67.199.85.166/main/maincatego...4x&brand=facto
Old 04-01-2009, 08:45 PM   #41
So Far I got:
Servo Saver Nut
Anything else?
Shocks?
Shocks
#1779 Blue Alum Servo Mounts
#3971 Steering Rack Bearings (4)
#1283 FT Turnbuckle Set for T4
FT Milled Motor Plate (blue #1770 or black #1778)
#9610B Servo Saver Bolt
#9665 FT B4/T4 Blue Hinge Pin Plate
Then if you want:
#9635 B4/T4 Sway Bar Kit
#6937 4-40 FT Blue Lock Nuts
#6943 8-32 FT Blue Lock Nuts
#7447 T4 Carbon Arms Front
#7448 T4 Carbon Arms Rear
#7922 GT2 30 Degree Caster Block
#9592 B4/T4 20 Degree Caster Block
#9577 B4/T4 Steering Block Inline (requires #9623)
#9623 FT B4 Front Inline Axle
Any of the Carbon FT T4 Arms Front or Rear
#9567 FT B4/T4 Carbon Top Plate
Not sure on the CVD's yet. Manual list T4/GT2 Dogbones, but I am guessing the appropriate CVD length may depend on if your using the Ball Diff or Gear Diff, since the Transmission case is different for each. Kurt or Rick may be able to speak to that.
Old 04-01-2009, 08:46 PM   #42
Lightin', where did you order yours from?
Jake O is offline   Reply With Quote
Old 04-01-2009, 08:54 PM   #43
jimcoracer's Avatar
So Far I got:
Servo Saver Nut
Anything else?
Shocks?
What about CVD's...the kit comes with dog bones.
Brian_R
ocrcraceway.com
jimcoracer is offline   Reply With Quote
Old 04-01-2009, 08:56 PM   #44
ckaspar's Avatar
Shocks
Then if you want:
Thanks! So basically all of the T4 parts then.
Now if I can just get one. I am told that my local Hobby People should have some on Friday so I will have to call them and see. They are offering it for like $179 so... We'll see
Old 04-01-2009, 08:56 PM   #45
You dont need the HD Servo Saver Spring. Its already in the kit.
Front Shock Tower on the SC10 is slightly different to account for mounting the Front Body Mount.
The Carbon Battery Strap cant be used on the SC10.
The Light Weight Outdrive set is for the Ball Diff.
Other than obviously the Chassis, knock yourself out.
Forum Jump
Team Associated SC10 Short-Course Racing Truck reenmachine Electric Off-Road 474 11-17-2009 10:04 PM
Slipping SC10 wet dif. Anyone? markhat250 Electric Off-Road 9 08-07-2009 03:46 PM
AE SC10 RTR ISSUES ABN Hoosier Electric Off-Road 21 08-04-2009 12:27 AM
Converting a T4 to SC10 henry Electric Off-Road 18 04-08-2009 05:10 PM
Thunder Tech CORR Pro 2WD build RC nut Electric Off-Road 33 03-01-2009 08:25 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
