Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-06-2009, 01:43 PM   #3271
smokinu's Avatar
Trader Rating: 23 (100%+)
The xl5 is a great esc paired with a novak regulater for lipo
T E A M T E R R I B L E S
West Coast Rep/Califronia organizer.
smokinu is offline   Reply With Quote
Old 11-06-2009, 03:10 PM   #3272
smokinu's Avatar
haha having fun with the auto timer on my camera.
Old 11-06-2009, 05:04 PM   #3273
JPMSRacing's Avatar
Location: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
I tried the added weight today, it was good forward traction, but to much weight in the rear and it would carry it around to far, so I lost lots of corner speed, so I will pull some out and see what it does.
http://jpsmobileservice.com
JPMSRacing is offline   Reply With Quote
Old 11-06-2009, 05:45 PM   #3274
JPMSRacing's Avatar
I pulled the weights out and the truck was much more responsive, I loosened up the slipper alittle and got my rear traction undercontrol, I have to say if you could keep oil in the shocks, this truck is just awesome.
Old 11-06-2009, 05:54 PM   #3275
Fast XXXS's Avatar
Trader Rating: 18 (100%+)
Ok guys just finished my SC10 build. Went together nicely! Quick questions? anyone running mamba motors in their trucks? i have found that the motor shaft is too long and stops the gear cover from going on fully, anyone else have this problem? Iv got a 6900 if that matters? Also i have an IP 3800 lipo that im gonna use in it but the battery strap covers the corally plug holes on the pack, and i dont wanna really dremel the battery strap, or is this my only option?
Cheers
Tamiya TA05MS/ KO Propo Helios/ LRP SPX/ Fantom ION 17.5/ SMC 5200/ Mazda 6
Associated SC10/ Mamba 6900/ Futaba/ Intellect
Fast XXXS is online now   Reply With Quote
Old 11-06-2009, 06:05 PM   #3276
JPMSRacing's Avatar
Cheers
I would say yes, I didnt blink and grabbed the dremel with a sandpaper drum and cleared me a spot for the battery plugs. Works great.
As far as the motor, hate to say it, but I grabbed a die grinder out of the service truck and chopped off the end and rounded it, motor runs fine and has a couple hrs on it now.
Old 11-06-2009, 09:19 PM   #3277
mhodgie's Avatar
Send a message via Yahoo to mhodgie
Default Finally...
Finally got a few hours to work on the truck this evening.
Finished setting up the RS with a 17.5, tested and put it back together...
Not the best solder job. Haven't quite got that part figured out.
Some more tweaks and it'll be ready for the track again!
Thanks,
Michael
SC10 | TC3 VTA | Rascal
mhodgie is offline   Reply With Quote
Old 11-07-2009, 02:00 AM   #3278
smokinu's Avatar
I'll be racing my mod sc10 in a couple hours will report back on how I do
Good luck to everone else racing this weekend aswell
Old 11-07-2009, 02:58 AM   #3279
Take apart the shocks and add some slime or AE black grease liberally on the o rings and reassemble. This seems to have cured my leaking shocks.
Honu is offline   Reply With Quote
Old 11-07-2009, 04:08 AM   #3280
Sith Lord's Avatar
I did this also. But I also drilled about 3/8 (maybe a bit smaller) holes in the strap near the pivot point. Looks a bit neater than sanding out near the twist knowbs
Beware of the Dark Side
Sith Lord is offline   Reply With Quote
Old 11-07-2009, 06:05 AM   #3281
dirtracer01's Avatar
Send a message via AIM to dirtracer01 Send a message via Yahoo to dirtracer01
Default What Battery's
What size and brand of NiHMs battery's are you guys running in your SC10's?
Member: NAMBA# 874
Team Terribles
Modesto RC Raceway
Traxxas Slayer
Traxxas Slash
dirtracer01 is offline   Reply With Quote
Old 11-07-2009, 06:15 AM   #3282
R-E-A-P-E-R-'s Avatar
Do peeps actually still run those???
----- Caster EX-1 - Caster F8T - Caster ZX-1.5R - Caster F18 -----
---------------------------- TEKIN ------------------------------
R-E-A-P-E-R- is offline   Reply With Quote
Old 11-07-2009, 06:25 AM   #3283
mhodgie's Avatar
I had one from cheapbatterypacks when I got my Slash but once I went LiPO I never looked back and gave that one away when I traded my Slash off. LHS got me started with a Duratrax 3700 that I still run along with my Checkpoint 4900.
Thanks,
Michael
Old 11-07-2009, 07:10 AM   #3284
Default Why Not
Why not Reaper is there a problem with running one?!!!!
Member: NAMBA# 874
Team Terribles
Modesto RC Raceway
Traxxas Slayer
Traxxas Slash
Old 11-07-2009, 07:33 AM   #3285
I guess not....
Unless your racing
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
igyrigged
Forum Jump
Team Associated SC10 Short-Course Racing Truck reenmachine Electric Off-Road 474 11-17-2009 10:04 PM
Slipping SC10 wet dif. Anyone? markhat250 Electric Off-Road 9 08-07-2009 03:46 PM
AE SC10 RTR ISSUES ABN Hoosier Electric Off-Road 21 08-04-2009 12:27 AM
Converting a T4 to SC10 henry Electric Off-Road 18 04-08-2009 05:10 PM
Thunder Tech CORR Pro 2WD build RC nut Electric Off-Road 33 03-01-2009 08:25 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
