Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-06-2009, 02:54 AM   #721
Default hyper
hi guys, i am new to the lipo scene. thinking of taking the plunge.
what are your thoughts on this hyper 9e.
are they durable. the stock hyper 9 had so much issues in england, hardly anyone running them now.
theres the new hyper 9 updated coming out. does the hyper 9 e share the same parts as the original version?
thanking in advance
muaythai is offline   Reply With Quote
Old 11-06-2009, 05:52 AM   #722
Hoag-Dog's Avatar
Send a message via Yahoo to Hoag-Dog
Sorry, I can't. This forum doesn't let me post pics until I have x amount of posts.
BTW I might have the right parts. Do you have to tap #29109? Mine is just about a mm too small for the shock shaft.
Hoag-Dog is offline   Reply With Quote
Old 11-06-2009, 09:14 AM   #723
Just push hard and thread them on. No tap needed. They're made to be hard to get on, so they don't twist off.
reracer is offline   Reply With Quote
Old 11-06-2009, 10:21 AM   #724
Hoag-Dog's Avatar
Smile
Thanks, I will be assembling the rest of it today!
Old 11-06-2009, 11:06 AM   #725
-R2-'s Avatar
Originally Posted by mrramirez View Post
Does anyone know who makes an aftermarket body for the hyper 9E. I noticed that proline makes a nitro body, does that one fit? I can't seem to find one, help will be appreciated thanks.
The Proline body will fit and just saw someone with a J Concepts on theirs but did not see what size battery was in there, the Hobao of course works and has alot more upper clearance for batterires, and just posted yesterday was the new BittyDesign Hyper 9 which looks cool they all are great looking bodies and I think they fit the best with a 3s without teaking over the body to one side but that's what I've been running in my 9E. I have also cut down my rear body mount to lower the body for a thiner look from the chassis to the top of the body, if I put a 4s it would not work and I would have to go back to the og mount position.
HYPER SC10 4X4
HYPER 9e,HYPER 9-JL PRO.21,BYRONS ORIGINALS
JAMMIN X2 CRT-PICCO EVO II,
DJ OFNA proud customer service tech.
-R2- is offline   Reply With Quote
Old 11-06-2009, 04:11 PM   #726
Hoag-Dog's Avatar
Im wondering what medusa motor would be best for a 9e on 4s?
Old 11-06-2009, 08:53 PM   #727
I used a Medusa 60mm x 2000kv on 4S in my Losi 8E and it worked very well. It ran warm, but never hot. It appears that Medusa still has at least one of the 60x2000 motors.
8Be - Tekin RX8 2000kv 4S
8Te - Tekin RX8 1700kv 5S
CRT.5e - MM/Medusa/3S
ZX5 SP - Novak/6.5
GO-RIDE.com is offline   Reply With Quote
Old 11-06-2009, 09:23 PM   #728
ZX5 SP - Novak/6.5
Old 11-07-2009, 12:10 PM   #729
Hoag-Dog's Avatar
I can't find any medusa in stock that would be good for 4s, can someone give me a link? I will also a purchase a almost or new motor from someone.
Old 11-07-2009, 12:16 PM   #730
According to Medusa's site they still have the 60x2000kv in stock, and for a great price.
Scroll down on this page.
http://www.medusaproducts.com/motors/036-V2.htm
ZX5 SP - Novak/6.5
Old 11-07-2009, 12:52 PM   #731
Hoag-Dog's Avatar
http://www.ewebcart.com/3806/cart?o=...s%2F036-V2.htm
Old 11-08-2009, 12:39 PM   #732
enrique125cc's Avatar
Hey What diff oils is everyone running im running what ever it came with and it seems that i cant get the tight turning that some of the other cars are getting on the track
Hyper 9 E RX8 1900kv 4s maxamps lipo
enrique125cc is offline   Reply With Quote
Old 11-08-2009, 03:37 PM   #733
Cain's Avatar
Trader Rating: 34 (100%+)
5-5-3 front to rear I believe is very common.
If you find you need more rotation, you can try 2K in the rear or even 1K. I was initially running the Hyper 9 nitro diff setup which I believe was 3-5-1 or something to that effect as found on nitrohouse. It had TOO much steering.
Please post your full setup, as well as full gear and track conditions. Also, post what tires and compound that others run on the track that works.
Academy GV2 Pro 1/10 Scale Brushless Buggy
Academy STR4 Pro II 1/10 Scale Brushless Sedan
Ofna Hyper 9E 1/8 Scale Brushless Buggy
Old 11-08-2009, 09:20 PM   #734
mrramirez's Avatar
Ok guys I read plenty of pages and did not find much help on gearing a mmm 2650 combo. Does anyone know what size pinion to buy, keeping stock spur gear (40 tooth) or maybe buying another spur gear with more teeth? My main concern is good speed and motor temp. Mostly making sure that I don't overheat my motor. Thanks help is appreciated
Losi 8ight B, nova plus 4
Losi 8ight T 2.0, V-spec .21
Losi 8ight E buggy 2.0 stock
Hyper 9E, MMM 2650 combo
mrramirez is offline   Reply With Quote
Old 11-08-2009, 10:00 PM   #735
"JR"Penny's Avatar
[quote=mrramirez;6581629]Ok guys I read plenty of pages and did not find much help on gearing a mmm 2650 combo. Does anyone know what size pinion to buy, keeping stock spur gear (40 tooth)? My main concern is good speed and motor temp. Mostly making sure that I don't overheat my motor. Thanks help is appreciated[/QUOTE
Gearing will depend on how much voltage you plan on running, ie 2s, 3s, or 4s, and size of track you plan on running on. With the MMM 2650 and the stock 40 tooth spur, the smallest pinion you can run is a 15t without grinding down the motor a bit. If you plan on running 4s a 15t to 16t pinion will give you good speed, and should keep the temps in check. A good 3s lipo can give you good speeds too. All I have is 3s lipos, and I run them on a med/sm indoor clay track geared with a 16t, and my temps are between 120-150 on both esc (no fan) and motor depending on track layout. I also run 3s out doors on large 8th scale tracks (revelation raceway) geared between 18-20t with similar temps and great speed. Hope this kind of helped.
OFNA
Hyper9e
Not as lean, just as mean, always a U.S. Marine.
"JR"Penny is offline   Reply With Quote
Forum Jump
Seen this yet? HoBao Hyper 9E. BAAAAAD! thuren Electric Off-Road 46 08-05-2009 06:24 AM
:::::Hyper ST Electric Conversion::::: Hyper ST-E Guy Electric Off-Road 11 07-19-2009 05:16 PM
My Hobao Hyper 9E wwam Electric Off-Road 20 05-05-2009 05:58 PM
Hyper 9E!! slaytanic Nitro Off-Road 11 02-11-2009 10:17 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
