Old 03-29-2009, 09:47 AM   #1
yfzracer912's Avatar
Default How to setup offroad suspension
I trying to dial in my shocks for the track but I cant seem to get them to work properly. What are the right steps to take when setting up your suspension? Shock oil first then ride height then spring rates? I m just unsure of how to setup the ride height. Do you use different spring rates to get it to sit right or do you use pre-load? Any help would be great thanks!
yfzracer912 is offline   Reply With Quote
Old 03-29-2009, 09:57 AM   #2
xDaRReLLx87's Avatar
Shock oil + Springs
Ride height
Increase spring pre-load to raise height, take away to lower
If you want higher spring rate, raise or lower the pre-load to get the height you had previously
Vertical Shock angle is for jumping big jumps, more angled shocks are for aggressive tight tracks.
Have you even tried google?
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Old 03-29-2009, 10:11 AM   #3
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
something else to look at http://users.telenet.be/elvo/
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 03-30-2009, 11:07 AM   #4
It's a combination of springs and pre-load spacers. Get the springs you think you will use first, then add pre-load spacers.
Put in the springs only then drop the car from about a foot above the ground. If you want "bones level" at the back, add spacers and repeat the process until the bones are level when the car settles.
Make sure it's at race weight first, i.e. motor, radio gear, battery all installed.
If you decide to change springs after a shake-down run,go through the whole process again, as it will settle at different height depending on spring tension.
JR007 is offline   Reply With Quote
Old 03-30-2009, 03:58 PM   #5
Ediaz's Avatar
good info
Ediaz is offline   Reply With Quote
Old 03-30-2009, 04:43 PM   #6
Trader Rating: 26 (96%+)
pick springs before everything else. Set them up so that you can get good rear traction w/out flying wheelies the whole time. Then set the shock oil so that when you land you aren't blowing out the bottom of your car. Then dial in the positions of everything to suit your driving needs.
party_wagon is offline   Reply With Quote
Electric Offroad at Pegasus Hobbies!!!!!!!!! Jeremy Felles California Racing 12144 Yesterday 09:05 AM
kyosho electric offroad b-man777 Electric Off-Road 9014 12-22-2012 07:36 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
LOSI 8 OR ASSOCIATED 8 which is BEST? Xray prince Nitro Off-Road 68 12-06-2007 09:43 PM
MRC / Academy SB Sport 4wd Buggy Cain Electric Off-Road 956 04-23-2007 07:56 AM
SEO by vBSEO 3.5.0
