Old 03-25-2009, 03:51 PM   #1
Frank L's Avatar
Trader Rating: 144 (100%+)
Default 4S 2200 Low Voltage Issue.
I have a 4S 2200 Losi lipo that the voltage dropped to 11.3. The electronics shorted out and sucked the battery down. It took a charge, it doesn't appear bulged or damaged and the hyperion charger said it checked out ok. I am new to lipo and Just wondering what the effects will be as a result of this low voltage problem. I dont want to get stuck at a race with a bad battery. Any experience or comments are appreciated.
- X-Ray/ RC America Team Driver - Triton Team Driver -
- XB8 - XB8 14T - XB8 E - OS Spec III - 4PXR - Futaba -
Old 03-25-2009, 03:55 PM   #2
I would try and discharge it on the charger if possible, before running it again, just be careful and if it is fine after a few cycles, try it in your car.
Do this outside/on concrete/in a safe (Read: non-flammable) area.
LRP Z.28R - 3
Spur Gear - 0
howtowakeakar is offline   Reply With Quote
Old 03-25-2009, 04:49 PM   #3
Trader Rating: 21 (100%+)
If it didn't get hot, its prob OK. Its a positive sign it charged and didn't have probs on your hyperion charger. I'd use it and watch it for a few cycles - look for any swelling or puffing, but sounds unlikely since voltage didn't get that low.
Duster_360 is offline   Reply With Quote
Old 03-25-2009, 04:52 PM   #4
xDaRReLLx87's Avatar
Did you balance it and charge it only at 1.5-2amps?
Sometimes a bad connection can cause that to happen.
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Lipo 4S or 5S vannon Electric Off-Road 23 07-11-2009 10:41 AM
SEO by vBSEO 3.5.0
