Old 03-23-2009, 06:54 AM   #1
Default Evader EXT
I have the Evader EXT and I seen a upgrade foe the Evader St the will make the tranny really strong.
From this site:
Megazone2311-25-2004, 11:07 PM
I haven't had any trouble with my tranny, but if/when I find it necessary to make my tranny bulletproof, here's what's in store:
- metal idler gear from the Nitro Evader ($17)
- metal diff gear from HGI for the B2/T2 (This will require a slight mod since the bearing hole is English, and the Evader uses metric. $20 according to the HGI site. You'll also need to replace the bearings. If I recall correctly, you would need to use 10x5 mm bearings, but bearings are cheap.)
- carbide diff and thrust balls ($17)
- Associated Stealth diff rings (B2/Ts) and spring ($3)
This should make it about as indestructible as I can imagine. The Modfather made these upgrades, and he said his tranny is silky smooth.
Does anyone know if this will work for the EXT and I don't need to get any othere part additional. Plus I can not fined the Metal Differential gear from HGI for the B2. Does anyone know where I can get that?
Thanks for everything!!!
neekcotrack is offline   Reply With Quote
Outdoor FREE Slash track in Seattle t0adman Northwest Racers 4229 09-07-2016 01:41 PM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 01:27 AM
Evader EXT, return it or keep it? Danny17 Electric Off-Road 9 07-04-2009 07:31 PM
DuraTrax Evader EXT ST EP RTR SirJangly Electric Off-Road 6 05-15-2009 09:47 PM
SEO by vBSEO 3.5.0
