Old 04-01-2009, 07:12 AM   #31
AndyMoore's Avatar
Trader Rating: 53 (100%+)
Send a message via AIM to AndyMoore
Originally Posted by thecman26 View Post
1 more question: I got my electronics and what-not installed. I noticed when I give it some "gas" on the stand and brake the front tires continue to spin freely. Also when I try to turn them backwards they lock up and dont turn.
Is there something wrong with that statement or is it "normal"?
I would have thought when you brake you get 4 wheel brake...
This being my first 1/10th scale 4wd buggy, I am a newb...
Thanks!
It sounds like the car has a front one-way, you might want to take a look inside the diff case to make sure. Initially the car came with a center shaft one-way, and we later moved to a direct shaft setup. The front one-way was used by those who wanted a lot of steering.
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 04-02-2009, 09:01 AM   #32
thecman26's Avatar
Trader Rating: 99 (100%+)
Aha.. Yeah you are probably right! I will investigate a lil more!
Cant wait to slap this thing on the track!
Thanks alot dude!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 04-02-2009, 11:13 AM   #33
Originally Posted by Toddzilla View Post
There is a BJ4 local to me for $150 that I was tempted to buy.
I didn't know that they used stick packs.
So how do you guys feel the BJ4 no WE stacks up against the XXX-4 G+?
Race:
Hyper 10 SC
SC10
XXX-T - Stock Truck
XXX4+g
Toddzilla is offline   Reply With Quote
Old 04-02-2009, 12:24 PM   #34
AndyMoore's Avatar
With the Worlds front bulkhead and arms, the car is far less fragile then the Losi. It really comes down to if youre running other vehicles from AE or Losi though...
Old 04-02-2009, 01:11 PM   #35
Yeah, I'm pretty much all losi. The only issue I've had with the XXX-4 is throwing belts from time to time. If you throw a belt and then shred it, it's a real pain in the ass because you basically have to dissasemble the entire car.
I've only owned one associated car, a B3 FT that I have collecting dust. Amazingly, I'm pretty sure it would have no problem competing today.
Race:
Hyper 10 SC
SC10
XXX-T - Stock Truck
XXX4+g
Old 04-04-2009, 11:43 PM   #36
thecman26's Avatar
Took the BJ4 out to the track for the first time last night.
Only broke 1 arm and had a blast!!!
Ten minute main was incradible too!!!!
I do have some learning to do, drives alot different compared to the T4!
Great product!!!
Going to put the B44 steering rack on it this week!
BTW the arms are soooo easy to replace in a snap!
Old 04-17-2009, 01:49 PM   #37
thecman26's Avatar
I had a blast with the new set-up, but this thing has WAY too much steering!
When I threw the new steering assembly on I noticed it has a one-way on the center shaft. Is there a standard non one-way piece to replace it with?
I tried to get some of the steering out of it and was pretty much unsuccessfull, any ideas?
Old 04-17-2009, 02:15 PM   #38
trx450racer174's Avatar
If you dont have a manual i can get you the p/n when i get home.
Does it also have a front one-way?
If you don't want the center one-way i believe you need p/n 1045, Its the direct center shaft kit.
E.K.D. RC Paint Work
Team Serpent USA, Desoto Racing , Team DE Racing, Team Hitec, Team Trakpower, Futaba, Team AKA, TrackstarRC.
trx450racer174 is offline   Reply With Quote
Old 04-19-2009, 10:04 PM   #39
thecman26's Avatar
I have the center one way at least, havent opened up the front diff case yet...
Old 04-20-2009, 08:36 AM   #40
AndyMoore's Avatar
Original BJ4 manual:
http://www.jconcepts.net/index.php?/...ail_details/28
Old 06-25-2009, 03:50 PM   #41
Super Moderator
Funkymojo's Avatar
Location: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
Trader Rating: 75 (100%+)
Originally Posted by Linkster View Post
I have a 1st gen BJ4 and I LOVE it!
It has Losi shocks, Lipo Tray, Double Front Shocktower, Aluminum Rear Hubs, and I have a set of aluminum rear a-arms to use when I feel like it.
It is just plain awesome, I drive it HARD and it just keeps coming back for more.
What Lipo Tray are you using Linkster? By the way, will the AE TC5 cf batt strap fit the originial BJ4? Cheers
WANKING - Extreme agitation and arousal - usually south of Nanking and short of Farking.
I'm neither a Mod nor a Rocker. I'm a Mocker.
Viper R/C Solutions | Atomic Carbon CR2 LWB | Darth Tray | Losi 8IGHT 2.0-E | Tamiya TRF801X-E
Funkymojo is offline   Reply With Quote
Old 06-25-2009, 04:27 PM   #42
porkey's Avatar
Hey Andy,
There is one guy at my local track who drives a BJ4 worlds and every time he strips a ring and drive gear he rebuilds it then puts a ton of diff lube one these gears. And the few guys that i talked to said they are self lubercatin gears. I let this person use my brand new diff lube only been used once and know my diff lube if almost gone. Now my question is do your really have to use diff lube on your ring and drive gears. I know you used them on the diff balls but i dont know about the gears it self. Let me know, Ty
AE T4: 8.5 AE B4: 10.5 AE B44: 7.5
www.michianabuildingsupplies.com(Sponsor)
www.embassyrcraceway.com
www.michianarc.com
www.steelmx.com(Sponsor)
porkey is offline   Reply With Quote
Old 06-25-2009, 06:37 PM   #43
J_P
J_P's Avatar
Originally Posted by Funkymojo View Post
Hi guys, will the AE TC5 carbon fibre batt strap fit the originial BJ4? Thanks
Just looked. No. The BJ4 was set up for 7cells, to allow for battery movement. The TC5 is only set up for 6 cell spacing.
JConcepts * Associated * Reedy
J_P is offline   Reply With Quote
Old 06-25-2009, 06:42 PM   #44
J_P
J_P's Avatar
Originally Posted by porkey View Post
Hey Andy,
Not Andy, but.
Sounds like the diff is too tight. Or he is hitting a lot of stuff. You don't need to put lube on the gears.
Old 06-25-2009, 06:46 PM   #45
porkey's Avatar
Originally Posted by J_P View Post
Not Andy, but.
He has it to lose IMO, I can slide the diff side to side when its all put back to gather.
www.michianarc.com
