Old 03-09-2009, 09:47 PM   #1
801Funk801's Avatar
Trader Rating: 16 (100%+)
Default Balancing Proline Switch on Epic Bead-locs.
I just installed some switchs on some epic bead-locs and they seem way out of balance. My question is do I need to worry about it much for just bashing and running around the BMX track or should I look into balancing them? If it is vital that I balance them what are the steps to doing that? Thanks, Travis
801Funk801 is offline   Reply With Quote
Old 03-09-2009, 09:51 PM   #2
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
Well if you mount each wheel on a front axle so it can freely spin, eventually it should settle with the heaviest point on the bottom. Then you should be able to place stick-on lead weights to the top of the wheel to balance it.
You probably won't need a whole weight either, even if they're way out of whack a half of a weight should be able to make a huge difference.
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 03-10-2009, 06:28 AM   #3
you can also use lead tape that you can get at golf stores.
demon510 is offline   Reply With Quote
SEO by vBSEO 3.5.0
