High Velocity Racing
renos ragu. tire additives,castle creations,tekin
factory team t4 ,electric converted 3.3 revo
whoever said power isnt everything obviously doesnt own brushless/lipo power
rdub202's pit and marshall
wow, bigger thank the Mamba Max?? I was hoping it was about the same size, and since it doesn't use the USB setup, won't cut the sidewall of the chassis anymore.
Academy GV2 Pro 1/10 Scale Brushless Buggy
Academy STR4 Pro II 1/10 Scale Brushless Sedan
Ofna Hyper 9E 1/8 Scale Brushless Buggy
they really need to ditch the fan..... thats one downdraw to the gtb you need the fan for mod.. .
if its bigger than the current mamba max ill have to pass and stick with my tekin rs..
i was really hopin to see a esc that will hand the gtb/lrp its ass. aside from the tekin
the fan is optional and comes right off...keep in mind it is proto case. It is about the same size as the sidewinder. I had to mount it sideways as the Academy chassis is very narrow.
If they can make it smaller then it will be better. To me the fan isn't the issue, but if I were to get one I want it to fit with out a problem in my RB5. If I have to mount it on it's side I would rather get somthing else (I am bing picky ).
Don't get me wrong I think the ESC will be great, and it will be one of the only ones that is up to par with the tekin (although I think castle started programing the esc on a computer). But for me I would like it to be smaller as mounting a huge esc in a TC of 10th scale buggy can be an issue. Also I hope the price in around the price of the MM.
they should change the motto from mak em cry to make roar cry!!
id sure hope thats a proto case.. and hopefully the price is right..
When can we expect to see this? I would like to use this in 1/10th scale.
Would the sensored motor have sintered rotor or lightened rotor? That would eliminate most of the reason for me to look else where...
Have hope for the new year! Slash 4x4 is bringing it on!
thats true, however, the Mamba Max fits the side fine in the Academy. I would assume then that the Pro is even wider than the MM?
The MM does fit in the GV2 and so does the Sidewinder although the Sidewinder is a little tight but no mods are needed to fit it in. The MM Pro from I been told is a tad bit smaller than the Mamba Max. Not sure when the consumer versions come out if they are going to ba any smaller or not. I guess we will just wait and see how it goes.
Team Driver for:
Castle Creations
Bumps and Jumps
Express Motorsports
D&K Air Designs
Karens Famous Cookies (Factory Team Eater)
The Hidden Hangar
Pro version Is gonna be only sensored? Any ideas ?
It will run both sensored and unsensored. It will automatically detect whether there is a sensor cable plugged in. If there is it will use the sensors for start up. If not then it will use normal sensorless startup.
