Does using the brake or drag brake charge the battery?
When you put on the motor controled brakes in an RC car does this feed power back into the battery and charge it a little?
I have a mamba monster and castle 1515Y motor.
Tekin 411 series did this in the day. It really helped, especially in 8 minute 12th scale. But then we only had 1400 and 1700 batteries.
Haven't seen it mentioned in any esc literature for quite a while though.
I did a test with a clamp type amp meter around the battery wire, and i found the current goes back into the battery when braking.
Hope this helps you all.
I would love to see KERS in RC. Tekin, Viper, LRP, get on this!
I nearly burned my battery on a downhiller!
Considering that the only brakes you have in a brushless system is when the ESC uses electrical current, from the battery, to slow the motor down, any amount of back-feeding from the motor would be cancelled immediately once you applied the brakes.
Coasting, is different, but how often does anyone here allow their car to coast for anything more than a few seconds?
The current from my amp meter switches direction AFTER i pull the throttle. This must mean that the drag braking is recharging the battery!
The esc acts like a full wave bridge rectifier [Turns AC into DC].
The motor becomes a generator from the kinetic energy of the moving car.
Keeping the mechanical brakes on a 1/8th conversion will give you longer battery life.
+1 don't see the use of mechanical brakes: more weight, more parts, more complicated, less room, no real improvement.. You can try them but honestly if you're used to electric cars it's not needed
