MBX5R Conversion Questions
i have a couple of questions regarding converting my mbx5r to brushless.
what conversion kit worked best for you?
what motor esc combo do like?
all i can have are 3s unless i upgrade my charger,
will this be fine or what about running in series 6s,
can this be done in saddle pack style or is there not room for two batteries.
what about a koyosho center diff? or replacement diff?
any other advise you can pass alone would be appreciated.
thanks in advance
thanks in advance
Tech Legend
thanks in advance
thanks in advance
http://www.casterracingusa.com/produ...6&cat=0&page=1
I wouldn't recommend 3S pack alone in a conversion. Guys tried this, and it can be done, but you need REALLY high end pack, with a high KV motor, and you are just putting more strain on the electronics and will most likely puff a pack.
Tech Legend
http://scriptasylum.com/rc_speed/_top_speed.html
Again, I would not do this without a really high end pack if I had to. And by that I would want it easily over 180 amps continous rating as I have heard from others who have used quality cells (6000mah 25C packs) that they puffed them when using a 3S setup with a high KV motor.
If you go 6S, you would want something in the KV range of about 1400Kv.
