B4 Lightweight setup
#49
Got tired of waiting for a AE T4 Light so!
Wonder how far I'm off from the AE T4 Light!!!!
Adjusted the B4 Light to fit my T4 FT.
Worked good (2/27/09) lead the first 8 laps of a 10 lap race, finished second!
Front
Shock tower = 2
Arm = I
Tower link = 1 w/ 3 washers
Hub = B
Height = just below level
Axle height = UP
C-hub = 25 degree
Bump = 2 washers
Toe = 0
1/2 ounce of weight in bulkhead
(Found this after I got home from the race as I checked the steering bearings)
Rear
Shock tower = 0 << drill the inner hole
Arm = I
Tower link = 1 w/2 washers
Hub = A
Axles = level
Wheelbase = Long
Anti-squat = 0
Shocks
Front = 25wt AE
Springs = Green
Pistons = #2
Limiters = 3 (inside)
Rear = 25wt AE
Springs = Black
Pistons = #1
Front tires
Proline Edges
AE rims
Rear tires
Panther Komoto Dragons
AE rims
Motor and ESC
Speed Passion 13.5
Core-RC 3250 lipo
Battery centered one pad front and rear.
Wires towards the rear.
Spur/P = 81/23
Track (Farmers Hobby Tampa, FL USA)
http://farmershobbyshop.com/
Bumpy
Med/high traction
Wet
Red clay
Practice the track was dry and sandy/dusty (they hadn't prepped the track "watered" yet) and this setup worked!
The red clay at that track has a lot of sand in it and there is a lot of loose sand/dust until it's watered.
Front
Shock tower = 2
Arm = I
Hub = B
Axle height = UP
C-hub = 25 degree
Bump = 2 washers
Toe = 0
Rear
Arm = I
Hub = A
Axles = level
Wheelbase = Long
Anti-squat = 0
Shocks
Front = 25wt AE
Springs = Green
Pistons = #2
Rear = 25wt AE
Springs = Black
Pistons = #1
Front tires
Proline Edges
AE rims
Rear tires
AE rims
Motor and ESC
Speed Passion 13.5
Core-RC 3250 lipo
Spur/P = 81/23
Bumpy
Med/high traction
Wet
Red clay
#50
Front
Shock tower = 2
Arm = I
Hub = B
Axle height = UP
C-hub = 25 degree
Bump = 2 washers
Toe = 0
Rear
Arm = I
Hub = A
Axles = level
Wheelbase = Long
Anti-squat = 0
Shocks
Front = 25wt AE
Springs = Green
Pistons = #2
Rear = 25wt AE
Springs = Black
Pistons = #1
Front tires
Proline Edges
AE rims
Rear tires
AE rims
Motor and ESC
Speed Passion 13.5
Core-RC 3250 lipo
Spur/P = 81/23
Bumpy
Med/high traction
Wet
Red clay
Front
Shock tower = 2
Arm = I
Hub = B
Axle height = UP
C-hub = 25 degree
Bump = 2 washers
Toe = 0
Rear
Arm = I
Hub = A
Axles = level
Wheelbase = Long
Anti-squat = 0
Shocks
Front = 25wt AE
Springs = Green
Pistons = #2
Rear = 25wt AE
Springs = Black
Pistons = #1
Front tires
Proline Edges
AE rims
Rear tires
AE rims
Motor and ESC
Speed Passion 13.5
Core-RC 3250 lipo
Spur/P = 81/23
Bumpy
Med/high traction
Wet
Red clay
just weighted my B4 with a 3800 and I still need 7 AE weight bars at 7g a peice and the 6 in the rear tranny to get to 1515 overall. I think it will just be easier to buy a reedy pack.
#54
I ran Cavalieri's CRCRC setup today for the first time at OCRC's hard packed clay track. The only change was a 13.5 brushless motor. Man, my B4 pushed like a dump truck. It was really stable but lacked agressive turn-in as well as overall steering.
Any suggestions?
Any suggestions?
Ft Tire ?
Did you use the .5 hubs ?
#55
Any suggestions?
Any suggestions?
The tires they noted as running were Proline M3 8175 ribs up front and M3 Square fuzzies in the rear, with buggy grip as tire sauce.
Also, they ran 25 wt front oil with only 1 limiter rather than 2.
Otherwise they were running the CRCRC set-up.
With these changes if you still are experiencing a push, try grinding down the front tires to give them a more worn look, this will make the nose of the car a bit more aggresive.
Also removing the 1/2 degree hubs and running the stock toe hubs will also free up the rear end.... I personally have not felt the need for the 1/2 degree hubs on an indoor clay track, as there most often already enough traction.
Another note, what gearing are you running on your 13.5? Have you gone to the newer style spur gears to move the motor further forward to compensate the the larger pinion gear needed?
#56
For the front tire, I used a set of "well scrubbed" 4-rib M3 tires that normally have a ton of bite.
As far as the .5 hubs, I actually ran the zero degree hubs and left the .5s in the box, since it would tighten the rear end even more.
Thanks for the input.
The track had just recently been redone to a new layout, so the bite was unusually high. I tried both the Square Fuzzies and the Holeshots in M3 and found the Holeshots a little better with the moister conditions.
Shock setup wise, that is definitely the direction I was going with the rear. I normally like a lot of down travel in the rear so when I'm hard on the brakes, it really allows the weight to transfer to the front end and gives me a ton of off power steering. The front shock length seems to be pretty close, just the right amount of on-power steering coming out of the corners.
I do not have the new spur gear yet and my car was definitely under geared even with a 30/81. That will be the next change that I make.
Anyways, thanks for the input. It is definitely appreciated. I could see how this setup would be great for the mod class. It is really easy to drive, super stable with a lot of rear bite out of the corners. But you guys know how the "stock" classes are: You gotta fling it in there and get in and out of the corners in a hurry.
I'll keep testing and making changes and I'll let you know what I end up with.
Thanks again.
It could be a few things. The set up a recieved a while ago from thielke and pudge donig testing for the lightweight set up was done on the OCRC track...
Thanks again.
#57
I ran the setup before with the .5s and it was about impossible to get the car to rotate into the corner. Without them it is a little better but the setup is still gives a lot of rear bite and in most cases a push. Green springs in the back have helped as well as 30 in the back.
#58
Rich , first thing I would try is a tire that steers more , like the Panther Switch , Losi Taper or JC Bar Code...
still have a push ?
try a stiffer rear spring first
try moving the rear hub back .030.
still have a push ?
#60
