-   Electric Off-Road (https://www.rctech.net/forum/electric-off-road-4/)
-   -   losi xxx4 temp problem (https://www.rctech.net/forum/electric-off-road/275898-losi-xxx4-temp-problem.html)
farny21 02-15-2009 04:36 PM
i have a mamba max 6900kv motor and esc and the motor esc and battery are getting hot and was wondering if its the gearing and if anyone could tell me what is a good setup that would be good. it has a 25pinoion and 92 spur and with a lipo its crazy fast.
C Reedy 02-15-2009 05:01 PM
well my friend has the 7700 mamba and he runs 16 pinion and 92 spur and his gets only warm... so i would think like around 18 on the pinion
farny21 02-15-2009 05:18 PM
k thanks ill try that and hopefully its still fast.
bigbadyoda 02-15-2009 07:26 PM
I can imagine how hot yours is getting.. my buddies 7700 on his mf1 we think is getting the transmission very hot thus heating up the diff gear and making the diff balls waller it out easily and strip it out from the inside out... with him running a 18/86
I'd suggest a 15 or so... I run a 16 and with a 18 it gets a little warmer but a lot faster :)......
Hows your buggy holding up besides the temp issue? belt working alright, looking at getting one but didn't know how it would hold up with the brushless in there..
BuggyKing 02-15-2009 08:12 PM
sounds like u are geared to high. I ran 94/18 and it came off 100 degrees.
BobWoodhouse 02-16-2009 03:37 AM
I run about 17 or 18 with a 94 when I race with a 5700, and it is about right.
farny21 02-16-2009 11:51 AM
i know im geared to high because of my temps and with a lipo it goes 60++++ but it gets to hot but its holding together fine, had a few high speed spils but other than that its a sweet buggy. and the belt sliped a little but after a little adjusting she has never since.
rcracer3533 02-25-2009 05:31 PM
Plan on running my xxx4 g+ with an orion 6.5 motor and a 94 spur gear. Running a high bite clay track, ground pink tapers, and track has speed sections as well as a couple technical spots. Just wandering if somone could point me in a direction of pinion size to try first. Thanks.
Alltapdout 02-26-2009 04:21 AM
17 would be a good spot to start.
bluexxxt 02-26-2009 08:03 AM
I got a tekin 7.5 in mine and I run 19/92 and it's slightly warm, certainly not hot.:sneaky:
