Old 02-13-2009, 04:52 PM   #1
Default 1512 In a Truggy
Will a 1512 "push" a truggy around on 5s? I am thinking a 1512 2.5D (2050kv) that I have laying around.
Thopper is offline   Reply With Quote
Old 02-13-2009, 04:55 PM   #2
SpEEdyBL's Avatar
Sure, just gear a few teeth lower than you would normally gear a 1515.
My vehicles (that work):
Custom experimental Losi 810/TEN SCTE - The fastest 1/8 scale buggy on the track - 5.2lb rtr - readily convertable to a ROAR legal 1/10 scale 4x4 SCT.
Custom Losi 8ight - lowest CG of any 1/8 buggy
Losi 22 Mid Motor
SpEEdyBL is offline   Reply With Quote
Old 02-14-2009, 07:29 AM   #3
TonysScrews's Avatar
With the newer lighter cars and trucks coming out, I wouldn't be surprised to see 1512's in trucks and 1509's in buggy's. It's the reason I bought the 1512 2.5D and 1515 2.0D for my Mugen conversions. They are both rated at 2050/kv and I plan on trying both motors in my MBX5T on 4S and 5S to see how they compare run time wise and powerwise. The MBX6T will be a LOT lighter like how the MBX6 is over the MBX5R so the 1512 should perform even better in the 6T. With mains at 10 minutes (once we have enough guys to have a class of our own) the required battery capacities will be much less. If you run a high efficiency setup the vehicles will be MUCH lighter with lower capacity packs as well thus teh need for less torque. The MBX6T with aluminum and Titanium hopups should weigh about the same as the older buggies (KII, KIII, Hyper7, etc) as well as some of the "heavier" newer cars.
Tony P.
Tonys Screws LLC
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 02-14-2009, 10:57 AM   #4
Trader Rating: 26 (96%+)
I would think the optimum setup would be like a 8s 3kmah lipo & like a 6turn 1512.
party_wagon is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18768 Today 10:26 AM
Losi Smart Diff Frank L Nitro Off-Road 580 06-25-2013 11:01 AM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19920 04-03-2013 08:30 AM
Novak 1/8th Scale Electric Conversion Kit Craps Electric Off-Road 297 01-19-2011 08:26 PM
RC8E, need some advice mondenet Electric Off-Road 8 03-21-2009 10:42 PM
SEO by vBSEO 3.5.0
