Noob question about charging
If I have this charger...
http://www3.towerhobbies.com/cgi-bin...&I=LXCNK7&P=FR And a 6cell 4500 mah nimh...do I charge it at 1 amps or 4 amps? |
4 amps will be fine. nimh batts can take quite a lot of amps.
If that is a new battery, it will also false peak a few times while "waking up". simply discharge, let it cool, then recharge, and repeat. i'd do it maybe through 4 or 5 cycles since that charger doesn't have a readout. |
Thanks. Yeah it's crappy, I have a nitro, so I never had a need recently for a good charger, but now I do!
What exactly do the amps settings mean? Like what is the difference of charging something at 1 amps vs 4?
With this charger, since you don't have any other options, charge your NimH at 4 amps. If you used 1 amp, you charge would take forever and you would not have much power when you went to use your pack. A better rate would be between 5 and 5.5 amps though...
A good charger to get by the way is the Duratrax ICE; it has a lot of different, but easy to use settings. |
