Old 02-08-2009, 07:08 PM   #1
theassuager's Avatar
Angry Temperature
I've got a Speed T set up for Off Road and wanted to know how hot is too hot for my motor and ESC? My speed control doesn't get very hot at all, but the motor and spool gear area get burning hot. This is after 20 mins of 60 mph runs up and down my street...
theassuager is offline   Reply With Quote
Old 02-08-2009, 07:28 PM   #2
Trader Rating: 23 (100%+)
well you shouldnt be over 180 degrees to be ran safely.
Mike Adamec
Trackside Hobbies
not home is offline   Reply With Quote
Old 02-08-2009, 08:01 PM   #3
JeromeK99's Avatar
Losi says that the motor should be no greater than 160-170 degrees.... You really should buy or borrow a temp gauge to measure where you are at. A lot of the heat may be from the wrong gearing for where you are running.. or tire slip.. You should be able to get a pretty fast speed using the 4800kv motor running off-road.. but it won't be as fast as the street. Traction is a big factor. Are you running the "locker" diff or diff balls? This will affect your traction bigtime in offroad. The locker will create a lot of extra tire spin in the corners.
JeromeK99 is offline   Reply With Quote
Old 02-08-2009, 10:42 PM   #4
I see. I got a ball diff in. I just have the stock gearing right now, I want to try to tweak it a bit to allow it to run cooler, but I don't know much about gearing... Thanks for the help guys, I'll hit up the LHS tomorrow after school...
Old 02-09-2009, 04:09 AM   #5
porkey's Avatar
I don't like to get over 130 on the ESC and the motor 130.
porkey is offline   Reply With Quote
Old 02-09-2009, 05:57 AM   #6
mamba max1's Avatar
Trader Rating: 35 (100%+)
sounds like you need a temp gun
mamba max1 is offline   Reply With Quote
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
Capricorn CL-12E engine blee Onroad Nitro Engine Zone 184 03-08-2014 10:33 AM
Rubber tires for dummies rayhuang Electric On-Road 391 06-02-2012 07:37 AM
Pro Trak NismoSkyline17 Electric On-Road 520 11-09-2009 07:33 AM
SMC 28C High Performance 4000mAh - 5000mAh Hardcase Lipos Danny/SMC Electric On-Road 420 04-24-2008 02:36 AM
TEAM BRAMBUS RACING Shacker Malaysian R/C Racers 154 12-29-2005 06:42 PM
35 Amp Graded cells from SMC coming soon EAMotorsports Electric On-Road 150 06-21-2004 09:53 AM
SEO by vBSEO 3.5.0
