Old 01-31-2009, 04:48 PM   #1
Default Motor wires
Hey guys Im hooking up my MMM v3 to my Neu and I was wondering. It doesnt matter which color goes to which terminal for the motor right? And if the direction is wrong I switch it in the esc software?
Speed_Freak_039 is offline   Reply With Quote
Old 01-31-2009, 10:40 PM   #2
if it is brushless then you will blow your speed control up..
B4 Racer1 is offline   Reply With Quote
Old 02-01-2009, 05:59 AM   #3
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
You don't switch it in the ESC software, no...
Make sure the wires are connected in the proper order... Since it's a sensorless motor, as long as, say, the white wire, is connected to the "white" terminal on the ESC, you'll be fine.
My 2nd Mamba Max is running the motor in reverse, no problem...
Sensored motors, you NEED to pay attention to the wiring order...
Sensorless should have a little more flexability...
But for convenience just plug 'em in, with the proper order
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
E-Jato - Diff still unloads in corners, with 100k weight oil in it!
drperry is offline   Reply With Quote
Old 02-01-2009, 07:14 AM   #4
With the neu motors it does not mater which wire is connected to any of terminal posts. If it is running backwards for your application ,just switch any two wires and it will reverse the rotation. The rotation cannot be reversed with the esc. only by physically changing any two wires either on the motor or the speed control.
Thopper is offline   Reply With Quote
Old 02-01-2009, 07:21 AM   #5
Trader Rating: 95 (99%+)
I'm sure you'll think I'm an ass and cuss me but, IF YOU DON"T KNOW WHAT YOU ARE TALKING ABOUT DON"T TALK!!!!!!!!!!!!
To answer the question:
This is the most incorrect statement that could have been made. Sensorless Brushless motors do not care how they get hooked up. You can connect the 3 motor leads in any order you choose. If the motor is running the wrong direction then you simply swap any 2 of the motor wires to reverse the rotation of the motor.
Sensored Brusless motors are a little different. They monitor things such as armature postition. They have to be hooked up in a specific order which will be labeled as A,B,C on the motor and the speed control. You just match letter to letter.
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
RC FLIGHT brading Manila Racers 23110 12-24-2015 06:23 PM
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! Joe Ford Team and Company Discussions 2363 09-07-2014 06:13 PM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19920 04-03-2013 08:30 AM
New Novak Brusless System danjoy25 Electric On-Road 2688 10-14-2010 08:40 AM
how hot is too hot peterel Rookie Zone 6 06-08-2008 09:00 PM
Question regarding Novak GTB's... Brushless Corey Electric Off-Road 9 02-13-2007 06:21 PM
Interference please help Mr-s413bt Australian Racing 17 05-04-2004 09:43 PM
SEO by vBSEO 3.5.0
