Old 01-31-2009, 11:22 PM   #16
MattWebb's Avatar
A frustrating thread to read.
Its gone from no sensor wire and smoke, to a pinion and spur problem.
www.teamadrenaline.net - your home for West Australia r/c race results and gossip
MattWebb is offline   Reply With Quote
Old 02-11-2009, 04:49 PM   #17
fasteddie2's Avatar
Trader Rating: 30 (100%+)
ok jake i had the same problem. I installed a gtb with a 17.5 in my bk2 and went up 5 on my pinion(22) with the stock spur gear(78). It was the slowest buggy ever! I call my lhs and the told me that i needed an 76 spur with an 39 pinion and alot of people are running with 43 pinion! WOW so for me to install this combo i had to make the slots for the motor a little longer so it would fit.
fasteddie2 is offline   Reply With Quote
Old 02-11-2009, 06:37 PM   #18
JeromeK99's Avatar
Sounds like it turned out to be a gearing issue... The 17.5 and stock 27t brushed motors are geared very very differently..
With a 27t off-road you typically gear from a 9 FDR to maybe 10ish... with a 17.5 you are looking at 5 to 6ish FDR depending on the track...
Brushless motors have to get up to speed before the power-band kicks in..
Have fun!
JeromeK99 is offline   Reply With Quote
SEO by vBSEO 3.5.0
