Old 01-30-2009, 06:57 PM   #1
snowboard094's Avatar
Default Best 11.1v lipo with more than 4000mah
I need a new lipo and was wondering with one to get. I need a 11.1v battery with over 4000mah. I was planning to spend less than $150. It will be going in a vxl slash.
snowboard094 is offline   Reply With Quote
Old 01-31-2009, 07:50 AM   #2
TonysScrews's Avatar
I have a killer deal for you then. I have a Poly RC 3S1P 30C 4500mah pack that is basically brand new (use the best cells made by Enerland). The 30C packs came with 8AWG wire (8mm fat) and I swapped out the wire for 10AWG (6mm thick). The 8AWG wire was too thick and heavy (Pack lost 41 grams just from changing the wire. It also went from 54mm wide to 48mm wide). After I changed the wire I re-shrink-wrapped the pack and then taped up the ends with black electrical tape for further protection. I even re-applied the sticker. I ran the pack twice to test it in my 1/8th brushless MBX5R. The 1/8th scale cars really need higher voltage so I never bothered running it again as I decided to stick with 4S so the pack is basically brand new.
It currently has a pair of Castle Creations 6.5mm gold bullet connectors on it but i can change them out to Dean's Ultra Plugs if you use them instead.
Poly RC PQ-4500XQ-3S Li-Poly Battery
3S1P 11.1V 4500mAh (3 cells) 30C/60C
Rating: 30C (135.0A) continuous, 60C (270.0A) burst
Dimension: 169mm x 48mm x 25mm
Weight: 375 grams w/ Castle 6.5mm bullet connectors
Termination: 10AWG Wire w/ Castle 6.5mm connectors & PolyQuest/Hyperion balance tap
The packs sell for $126 plus shipping at RC Lipos:
The pricing on batteries has come down because I paid $169 for the pack a few months ago. But my loss is your gain. I'll sell you the pack for $100 shipped USPS Priority Mail.
Original 8AWG wires:
With the 10AWG wire and Castle 6.5mm bullet connectors:
If interested, email me at sales@tony1034.com
Best regards,
Tony P.
Tonys Screws LLC
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 01-31-2009, 08:29 AM   #3
pull-start's Avatar
Trader Rating: 27 (100%+)
WOW !!! You asked for a killer deal and it looks like Tony hooked you up. That 30C pack will make your VXL FLY!!!
pull-start is offline   Reply With Quote
Old 01-31-2009, 10:24 AM   #4
DHC6's Avatar
If you don't pick up that pack then you can try True RC packs. The work very well for me, and the price is very good. I just picked up a pair of 3S 11.1V 5000mAh batteries for 80 bucks each. 180 shipped both of them to my doorstep.
Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return - Leonardo da Vinci
DHC6 is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19920 04-03-2013 08:30 AM
MBX5-R Brushless Conversion turb06le240 Nitro Off-Road 28 03-04-2008 06:26 PM
SEO by vBSEO 3.5.0
