xxxt-cr
Old 01-27-2009, 07:58 AM
rcracer3533's Avatar
Default xxxt-cr
I know we already have a thread for the xxxt-cr but it just has to many pages to try and sit to read through. I wanted to start a thread to try and find hop-up parts for the truck. I know lunsford has turnbuckles and such but where can i find titanium screws and different stuff for the tranny. Just looking for anything that anyone has found that helps the truck. Surely someone has done something with the truck rather than box stock that has helped in some area.
Thanks.
rcracer3533 is offline
Old 01-27-2009, 11:23 AM
grapejuice's Avatar
Trader Rating: 152 (100%+)
The first thing you should do is get ti ball studs for the rear hubs, the stock ones break easy and those alum. hubs are not cheap to replace if you break off a ball stud in them. Other than that, you really don't "need" anything else as far as hop-ups go.
grapejuice is offline
Old 01-27-2009, 03:46 PM
ChrisWolfson's Avatar
I echo that. Put some ti ballstuds in the rear hubs. I'm still running the stock turnbuckles. Replace them as you break them. The Losi aluminum front and rear pivot blocks could be an advantage, especially to pick up a little weight from running Lipo batteries. Other than that, run it as is!
ChrisWolfson is offline
