Old 01-24-2009, 01:45 PM   #1
boborc's Avatar
Default Ball differential Advice
I have had it.does anybody have any idea's or tips on how to make a ball diff's last longer between rebuilds? I race AE t3,t4.GT, & GT2 and I have to rebuild my diffs after every 10 minutes on the track. They feel gritty after just 2 heats. I have tried to use a different grease in the thrust bearing,No luck.I have tried acer ceramic balls.There is no dirt getting inside.does anybody have any other tips they would be greatly appreciated
boborc is offline   Reply With Quote
Old 01-24-2009, 02:32 PM   #2
Super Moderator
Be sure you are keeping it tight, no slip. The slipper should always slip first.
Check the setting on a new diff after running few minutes, they bed in a little. Some guys hold one wheel, the other in the air, and run the motor part speed for a few minutes for break in.
Also be careful that you are not overtightening the diff, that can put spots in the rings & balls. Take your time tightening it, check it, tighten a little at a time. Perhaps a 1/8 of a turn at a time. Replace the lock nut every couple builds, after a while they won't hold setting.
Tighten the slipper more than normal, lock both wheels, then turn the spur gear with your thumb. Should be pretty hard to turn, and the slipper should slip. Then loosen the slipper to suit.
The stock AE greases are top notch, use them. Not a lot of the clear silicone on the diff balls, a dab on each ball on each side, use a lot of the black on the thrust.
Go back through your manuals, make sure everything is correct. I haven't ran a AE tranny in a while, but when I did their manuals were quite good on diff building.
I know it's tough at first, but you develop a feel for it after a while. Done right they should go quite a ways, I run them for months typically.
Somebody at your track should be able to help as well. Good luck.
Dave H is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 45137 Today 12:48 PM
Tamiya mini cooper sipaboy Electric On-Road 28234 10-22-2016 12:20 AM
Team Magic G4 Motorman Nitro On-Road 11757 10-11-2016 09:24 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 07:17 AM
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
8ight roller question shurcooL Nitro Off-Road 6 09-03-2008 08:01 PM
SEO by vBSEO 3.5.0
