Old 01-23-2009, 04:47 AM   #1
lookieaefanboi's Avatar
Trader Rating: 37 (100%+)
Default B44 slipper help
Does anyone have a routine to see if the slipper is set properly?
lookieaefanboi is online now   Reply With Quote
Old 01-23-2009, 05:13 AM   #2
They say to let it slip a few feet when blasting off in a straight line. But in reality I find you set it as tight as you can while maintaining a controlable car! if your car squirels at the first pull of the trigger, try loosening it a bit untill you can control it. Of course, if you are running a too powerfull motor that might be the problem rather than the slipper. No use running a 3.5T brushless if you need a completely slack slipper to control it (which will just wear out the slipper).
Hope this helps!
CODMAN is offline   Reply With Quote
Old 01-23-2009, 06:16 AM   #3
Set it so it slips for 2 to 3 feet when you nail the throttle on pavement. you can make small adjusments for the track from there. The slipper isn't really meant as a traction control device, it's to save your drivetrain, so you don't want to go too far either way.
cjtamu is offline   Reply With Quote
Old 01-23-2009, 06:49 AM   #4
RCHR's Avatar
My car works pretty good set at 10mm per the instructions...
Radio Control Hobbies & Raceway
1258 South Main Street, Waterbury, CT. 06706
203-575-9757 / www.rchr.biz / rchr@att.net
RCHR is offline   Reply With Quote
XX-4 Forum knucklebusta Electric Off-Road 4036 06-10-2016 05:15 PM
Tamiya DF-03 type tom_chang79 Electric Off-Road 1048 01-17-2016 09:06 PM
Team Associated B44. Race, Tune and Modify Shadows Electric Off-Road 6171 08-09-2015 07:32 AM
SmacTrac...St.Louis Indoor Off Road smac Kansas/Missouri Racing 24520 04-01-2015 03:02 PM
Team Associated B44 is for REAL tyreguy Electric Off-Road 3181 10-10-2010 10:58 PM
Project Team Kassanova K2 buggy eds24 Electric Off-Road 89 05-06-2009 09:57 PM
SEO by vBSEO 3.5.0
