Old 01-23-2009, 04:30 AM   #1
Default Questions on lubricating
Hi there,
I'm a newbie in R/C and I am about to lubricate my just renovated tamiya manta ray.
I am considering using regular lubricants available from the hobby store or even the bike store, because I find R/C lubricants so expensive for the quantity.
On ballbearings : good clean + teflon spray grease
On nylon gears : teflon grease or MoS2 automotive grease
Dogbones / driveshafts : teflon grease or MoS2 ?
In ball diff : teflon grease ?
What do you think ? Any thoughts are appreciated !
Would you use teflon spray grease on nylon gears, spurs... ?
pylamy is offline   Reply With Quote
Old 01-23-2009, 09:29 AM   #2
In the ball diff I would not trust anything apart from the team associated stealth diff lube
here's a link for that:
For the nylon gears I use whit lithium grease.
For my ball bearings I use Fantom bearing oil
Heres a link to that:
For the dog bones and out drives I use a dry lubricant.
I wouldn't use any type of grease of lubes that don't dry completly because it will attract dirt and wear out those parts real quick.
You don't need anything for the spur gear.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 01-23-2009, 07:17 PM   #3
BIG RE's Avatar
Trader Rating: 31 (100%+)
on bearings I use trinity royal oil, and I havent used it, but "dry ice" by sullivan is supposed to be really good stuff, it dries and leaves a lube film
BIG RE is offline   Reply With Quote
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 11:02 AM
Methods for cleaning/lubricating bearings? Chris__RC Nitro Off-Road 37 04-24-2009 07:35 PM
GOOD FUEL scarlet Nitro On-Road 147 03-10-2007 08:41 AM
A few lathe questions Joe Electric On-Road 14 08-19-2002 05:03 AM
SEO by vBSEO 3.5.0
