Old 01-21-2009, 01:10 PM   #1
LT280z's Avatar
Trader Rating: 28 (97%+)
Default B4 wheels on B3???????
I dont have my B4 with me right now and was going to order some wheels. Does anyone know if you can use B4 wheels on a B3 buggy?????
I know the shaft is the same size but im wondering about the offset?
I cant find B3 wheels anywhere so im looking for an alternate solution
Any help is appreciated
LT280z is offline   Reply With Quote
Old 01-21-2009, 04:19 PM   #2
ta_man's Avatar
Trader Rating: 146 (100%+)
B4 wheels have a different offset than B4 wheels. The fronts are probably close enough that it doesn't matter much, but B4 rears will make a B3 much narrower. The thing to do is get the Evader Nitro BX rear wheels. They have the same offset and same axle size as the B3. I have lots (Tower had them on sale once in GREEN for $1.55 a pair and I got a bunch to use for bashing.) They work fine. Here are the white ones:
I think they are actually better (stronger) than the Associated or Pro-line B3 rear wheels.
ta_man is offline   Reply With Quote
Old 01-21-2009, 05:06 PM   #3
Trader Rating: 23 (100%+)
Send a message via AIM to AxiomJacob
B4 wheels on the B3 will narrow the front end up a little due to the offset in the rim itself.
Proline Racing
AxiomJacob is offline   Reply With Quote
Old 01-21-2009, 06:39 PM   #4
Bugle's Avatar
You can swap B4 hub carriers onto the B3 with the pin hole enlarged to 1/8", then use B4 driveshafts.
Bugle is offline   Reply With Quote
Old 01-22-2009, 12:18 PM   #5
LT280z's Avatar
Great info thanks guys!
Old 01-22-2009, 10:41 PM   #6
asbe88's Avatar
wheels from my b3 fit on my b4, (not so well because you have to cut the holes bigger in which you put them on) but I have never tried the other way around.. like I said they may fit but won't be as reliable and easy to use if you had the b3 wheels. my b3 wheels are so tight on my b4 that i try and get away without using them.
asbe88 is offline   Reply With Quote
Tamiya Championship Series Neil Rabara Racing Forum 20769 09-14-2016 05:06 AM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
Associated Wheels help OI812 Electric Off-Road 7 05-19-2008 07:43 PM
Indoor Dirt Racing @ RC Performance in Madison squirrel Wisconsin & Illinois Racing 4856 05-11-2008 05:25 PM
Still running a B3? Bikerbob Electric Off-Road 25 04-10-2008 04:40 PM
SEO by vBSEO 3.5.0
