HELP - TEKIN RS PRO
HELP - TEKIN RS PRO
need help... probably something stupid... Car will not turn one way and be on gas at same time... works fine the other way.... Also, if i turn the wheels that same way at a stop and then give it throttle - i get nothing.... doesnt move... When i straighten the wheels it goes forward....
IDEAS???? SUGGESTIONS????
have u tried replacing your reciever?
receiver is brand new.... I will try switching it out....
any other suggestions? could it be some sort of glitch because of interference?
Seriously, sounds like a radio problem. Quickest way to determine that is to hook up your RS Pro to your buddy's radio (that is known to work) and test it out.
Conversely, you can hook up a known good speed control with your radio and if that behaves, it's the RS Pro...
Did you recalibrate your RS Pro to your throttle? I think all ESCs has some button or routine to get the end-points of throttle/brake and neutral point of a radio.
I'm sure you know, but CH1 on the receiver is for the steering servo, CH2 is for the speed control.
swapped receivers with another one from one of my other cars.... Same model receiver.... Still had same problem....
i can sake a servo out of another car.... Servo is new.... I am pretty sure it happens only at full lock.... Thoughts?
if i adjust the travel (which i assume is the same as epa) to 60% the problem seems to go away... I was just trying that as you suggested it... Does 60% seem low? I need to confirm that the wheels are at full lock at around 60% to see if that is the limit... It might be??? It is a 4wd buggy if that makes a diff... on my stadium truck the travel is set to 100% with no problems...
As a point of interest... at about 65% the problem is intermittent and the wheel on the side of the issue seems to rotate a bit on the rough side...
Are you sure you have a full battery?
not full battery but plenty of juice left....
I would also check the motor, I know when I was running a 278 in my 4wd in would do weird stuff on the straight, especially later in a race when the battery had fallen off a bit but I later found out it was taking all the power for the motor and not giving me enough for my steering servo which would cause the car to veer on the straights at full throttle....something to check out.
tekin redline 5.5, smc 4900 saddle pack.... should be plenty of juice...
you mean what are the settings i am running?
