Will Losi electric conversion kit work on 2.0 T?
yes fits perfect on the 2.0 buggy im sure it will fit the 8t 2.0
janks
janks
sorry i cant help with that one we ran the losi motors in our convertion
janks
janks
I saw some pics of a losi b 1.0/losi conversion on the starting grid with a neu motor posted yesterday. I looks like if you use the novak/losi pinion the neu is ok. The Novak pinion is longer then the robinson. In fact I used the novak pinion on my medusa/mbx6/rcmonster to get the correct fit. The medusa and neu have different end bell configs. Not sure if the flat has t be extended when using the novak pinion.
I have the Castle-Neu combo in my 2.0. No problems using the Losi pinions, they fit just fine. You will have to get new screws to mount the motor. The only mod I had to do was grind down the rear motor support. Because of the finned case the motor diameter is larger than the Losi motor.
i will be moving to losi E-8ight-T 2.0.
Guest
hows that 2200 kv in thet buggy it must be insane i have the 2200kv in my 8t and its crazy power!!
Hey guys a little off subject will the losi 8ight t conversion work in a hellfire?
