Generic Dean's Connectors?
My issue with Dean's is the inability to buy more than 1 or 2 per pack, and it seems when I need them no one has them or it's not worth spending $2 on gas for a $2 part. The only thing I can find in bulk is generic Deans, which I'm guessing are probably just as good. Anyone use them? You can get 20 connectors for $6.50, seems to be all right by me. Conductivity is a good thing, however I raced my Slash on Saturday with electrical tape holding one of the wires to the connector tab!
https://www.hobbycity.com/hobbycity/...idProduct=2116
resistanc isn't a problem with the ganaric deans, melting is
I use generic Deans plugs. They are called Duratraxx or something. They work perfectly fine. Some I have tried have the plastic surround melt if they get too hot by leaving the soldering iron on too long, but if they are soldered properly, they are fine
stick with the deans.. they do have them in a five pack or something of the sort... i saw them in a hobby shop somewhere
I test a lot of packs for ROAR lipo testing. During the short circuit test - the "fake" deans connectors will melt off as the connector builds up heat from the high current draw (60+ amps). The Real Dean's connectors don't heat up nearly as much and don't melt off.
Buy the real stuff.
Buy the real stuff.
I agree, the generic ones can't handle the heat, and don't seem to have the same over all quality. Your Local HS should be able to order or may carry the Deans in packs of just female and male. I forget the quantity, but it's well worth it to get the packs of each, or just a pack of what you need.
I use the generic version from Hobbycity.com, and I recommend them. They are made of nylon, which does not melt like some other generic connectors. They hold solder fine. They are a little tight connecting and disconnecting for a while, but loosen up to be just right after a couple dozen connections.
I suggest that you buy a pack of 10 pairs and try them yourself. Form your own opinion of them. I'm confident that you will like them. They do what they are supposed to do, and do it well. Who cares if they aren't name brand?
Johnny
Johnny
Johnny
Johnny
Yeah.. All the reviews on there seem to be good. Everyone who has not to use them has never actually used them. Is Dean's available in bulk? Like 10 or 20 packs? I'm sick of getting a plastic bag with 2 connectors in it, what a waste of materials.
Think about it a little.. you can probably afford to go cheap if you have simple charging leads or very low current applciations.
If your running a higher end setup, esp with BL & LiPo then you probably *really* want better quality..
Have you tried these connectors?
For that matter, I'd like to hear from anyone who has actually used these connectors.
