Team Associated making an RC8E?
Who did you hear that from?
This setup has been working very well for me and I am using it only for racing, not bashing applications:
Motor: Neu 1512 2.5d/f
ESC: Mamba Max w/fan (until my Monster Max arrives)
Battery: ThunderPower eXtreme v2 5000 mAh 4s 14.8v
Spur Gear: Kyosho 46T (a LOT quieter than the stock steel spur gear)
Pinion: 19T
Run Time: approx. 18-22 minutes
Pinion: 19T
Tech Legend
Right now it appears that the common thing to go with is motors in the 2000Kv or less range, depending on cell count. The Neu 1512 2.5D is becoming a popular motor and it is 2050Kv. the Medusa 2000Kv 60mm V2 motor also works quite well.
As for ESCs, guys are using a range from modded Mamba Max ESCs and Tekin R1 Pros to the Mamba Monster ESC and lutach is using one he is working on to get distributed.
As for battery cell counts, 4S and 5S are the most popular. With the higher end selection being anything Enerland cell based, and the cheapo Zippy lipos that appear to work good.
If you do the center 46T plastic kyosho spur thing, you need to do alittle shimming changes, minor, but still something to keep in mind.
I run the following right now:
Neu 1512 2.5D motor or Medusa 2000Kv motor
PolyRC 4S 25C 6000mah battery pack
RCPD conversion
Mamba Monster ESC V1 (still works, knock on wood)
The 6000mah pack I use is probably as heavy as I would go.
RCPD conversion
