Old 01-04-2009, 11:19 AM   #1
Default when cleaning a diff....
do you have to use NEW parts or can you simply clean what you have and rebuild? I haven't run mine a lot but I have the afternoon free and figured I would clean it up a bit if possible...
when cleaning things, do you need a special type rag that doesnt leave lint and stuff or just clean it real good with paper towels?
Bump is offline   Reply With Quote
Old 01-04-2009, 11:50 AM   #2
You don't have to use new parts. Most people do because they are either rebuilding to keep it like new, or something is busted.
I rebuild mine from time to time just because I like wrenching
If you are re-using all of the same parts, keep the plates in the same order you took them off the car, that way you should definitely have no issues when it goes back together.
Also, make sure you have black grease and diff lube on hand. Of course
JR007 is offline   Reply With Quote
Old 01-04-2009, 12:04 PM   #3
All I do when I take apart the diff is take all parts out, clean them with either namptha or motor spray, then coat each ball a little bit with grease. Install the balls in the gear, and put a layer or grease over the balls on each side. Then do a layer on the thrust on each side. Remember to clean off the thrust bearing as once I put too much AE black greas eon the thrust, my diff was gritty, and when I opeaned it, it was ALL black! You flip the rings if they look worn, but then you have to rebreak them in, [see bfastrc thread for how to break in a diff].
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Team Corally RDX Touring Car Kenshin Electric On-Road 10561 11-20-2015 11:54 PM
Team Corally RDX Phi syndr0me Electric On-Road 3380 03-11-2014 10:27 AM
Hyper 9 Kits in Stock! bola Nitro Off-Road 2373 01-02-2013 03:43 PM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
Diff Cleaning Solvent rcgeezer Nitro Off-Road 23 05-22-2009 01:36 PM
Team Magic E4RS Rubber Spec kúv!n Electric On-Road 16 02-27-2008 03:12 PM
Do you get 50/50 enjoyment out of this hobby.... Mabuchi540 Electric On-Road 35 05-05-2005 08:47 PM
SEO by vBSEO 3.5.0
