Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-03-2009, 12:53 PM   #916
MUDVAYNE's Avatar
Trader Rating: 41 (100%+)
Chazz, specail delivery coming your way via USPS. Should be there Thursday or so.
Dan, what are you running for tires and inserts at CRCRC?
Team Holly Rollers
Alien ArtWerX - Custom paint, paint masks, and vinyl
Tekin products all the way!!!!!
MUDVAYNE is offline   Reply With Quote
Old 11-03-2009, 01:35 PM   #917
I was trying to get into the build manual on your website, but says it I can't view it because the link can not be found. I need the extra gear for the transmission that comes with the X-60 kit. I have all the other pieces insidethe trans/diff for it. What is the number for the 4th gear? Is it the same as one of the other idler gears?
Thanks,
Stephen
#1 X-60,Novak GTB SS, 13.5 Ballistic
#2 SC10 Novak Havok 13.5T,Calibers
#3 FT T-4 Brushed Reedy something. It's fast though!!
#4 Jammin X1CR FTE, EB mod V-spec
Hitec, Spektrum, M-8, Pro-Line, J-Concepts
toobad4u is offline   Reply With Quote
Old 11-03-2009, 01:43 PM   #918
Thanks,
Stephen
The 4th gear should come with the kit. And yes it's just another idler gear.
X-60: 8.5
FT b4: 13.5
FT B44: 7.5
x60Driver is offline   Reply With Quote
Old 11-03-2009, 02:56 PM   #919
Paul_Sinclair's Avatar
Send a message via AIM to Paul_Sinclair
Thanks,
Stephen
Where were you trying to find the instructions? I just checked both the X - 60 and X - 6 Squared instructions on the site and they worked fine for me: http://www.xfactoryrc.com/rc/Tech/In....php#X60Manual
To answer your question, X60Driver is right both idler gears in the transmission are part # AE 9360 Idler Gears.
X Factory - Novak Electronics - SMC Batteries - Vinyl Graphics Unlimited - Kolors By Kropy - Lunsford - MIP - B Fast Performance Diff Parts
Paul_Sinclair is offline   Reply With Quote
Old 11-03-2009, 03:04 PM   #920
Thanks for the replies. I was looking under the x-factory store under kits and there was a hyper link for the manual there. My transmission was really notchy, so I am replacing all the bearings and gear in the trans, and completely rebuilding the diff while I am in it.
Stephen
Old 11-03-2009, 04:56 PM   #921
Racerx336's Avatar
Anyone got a X6 or X60 they are wanting to get rid of?
- RC8e
- RC8Te
- XFactory X5
- XFactory X60
Racerx336 is offline   Reply With Quote
Old 11-03-2009, 05:46 PM   #922
Stephen
Ah, thanks, I'll have to fix that so it points to the right location.
Old 11-03-2009, 06:28 PM   #923
Pink bk bars in the back with jconcepts And-1 foams and jconcepts green groovy's up front with 3/4 losi stock foam in them
X-Factory, Jconcepts, BFastRc, 2 Brains Designs, CRCRC.com
DanGriffin is offline   Reply With Quote
Old 11-03-2009, 06:45 PM   #924
MUDVAYNE's Avatar
You have a pm sir.
Team Holly Rollers
Old 11-03-2009, 09:25 PM   #925
MaTt 93's Avatar
Send a message via MSN to MaTt 93
HI
Just wondering if anyone has run the smc side wire 5000mah lipo in there x6^2. And how did you get it to fit in ?
Matt
I'm not a hack, it simply strategic plowing
MaTt 93 is offline   Reply With Quote
Old 11-03-2009, 11:10 PM   #926
SpeedyPenguin's Avatar
Originally Posted by MaTt 93 View Post
HI
Matt
The wires should be fine, I run a Trinity pack with the same sort of wires, they exit near the endbell of the motor, height wise I don't know as I only run small packs in my X-6^2
X-Factory - BC1 Graphics - Trinity - Lunsford - Team Kinwald
SpeedyPenguin is offline   Reply With Quote
Old 11-04-2009, 06:49 PM   #927
Default motor choice
Getting my X60 put back togther in the next couple days. I have access to a Castle Sidewinder/5700kv combo and a Novak GTB/13.5 Ballistic combo. I can change the rotor/stator in the Ballistic motor to a different turn if neccessary. The tracks local to me run mod class so I can run either one. Which one of these 2 would you run.
Right now I am running a brushed Reedy motor (not sure of the turn) in my other T4, and it seems to be almost enough motor. Could use a little more every now and then ya know.
What esc/motor combo is in your trucks? I tried the search this thread option but didn't have a lot of luck.
Lastly, how fast do you get parts shipped out once they have been ordered from your website.
Thanks,
Stephen
Old 11-05-2009, 12:18 PM   #928
The 5700 is a ton of motor to much for 2wd IMO I would go with the 13.5 unless the track is massive. I run a 10.5 in my truck and it is great on a small/mid sized track.
This is a vid of the size track I am referring to most people run 8.5 to 13.5 in mod.
http://www.youtube.com/watch?v=Y07HASlHMI4
cmain is offline   Reply With Quote
Old 11-05-2009, 03:38 PM   #929
rcman1993's Avatar
that truck is hooked up. is it yours?
FT T4 racing mod and pro stock
SC10 =)
M11 with Pro Module
Airtronics, Futaba, LRP, Novak, Team Associated, Spektrum
Larrys Performance RCs
rcman1993 is offline   Reply With Quote
Old 11-05-2009, 05:02 PM   #930
Yep it is getting better it is not a x60 but getting close The 4 geat trans made a huge difference.
ROAR Region 8 race this weekend at SmacTrac I am going to do my best to get a good showing for the x-6 in stock buggy.
Forum Jump
Micro On Road & 1/18 Off Road Nats Thread RCMadness Micro and Mini Scales 400 11-14-2009 06:37 AM
2009 European Championships oople Electric Off-Road 24 08-15-2009 12:06 PM
S.N.O.W.S. 2008-2009 Season @ Mikes' RC World GasserX Northwest Racers 347 03-30-2009 08:49 PM
+ NITRO CLEARING HOUSE!!GREAT PRICES!!ENGINE-SMART TEMP-BOTTLES-FUEL-BATTERIES!+ R/C NYC R/C Items: For Sale/Trade 9 02-05-2009 10:17 AM
MNC EP 2009 Rd 1, Kota Raja RC Track, Kelang - 1st February 2009 bgdesmoulin Malaysian R/C Racers 181 02-03-2009 05:38 PM
2008 1/18 Indoor Off Road Nats @ R/C Madness RCMadness Micro and Mini Scales 193 07-09-2008 03:30 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
