traxxas ESC melt down
I have a traxxas e-maxx and when crawling at low speeds the ESC melts down.WTF!!!!!!!!!!!....plz help
anything binding?
no not that i can see or feel......the only thing different from stock is i have a little bit taller then stock tires on with shot in them for crawling....iam on esc 3 in a week
crawling as in rock crawling ?
you need to change gearing if you have not done that yet if you are causing the motor to stall while crawling it will burn the esc. quick |
Def need to change to smaller pinion, stock gearing with those weighted tires is way too tall - overgeared due to the wheels and their weight.
what is the stock gearing and what gearing should i go to?........and should i try a 2 speed?...thank you.
